a noise..... - Defender Source
Old September 11th, 2005, 05:33 PM
a noise.....
Sometimes when I drive on a rough surface, dirt roads, rocks etc I will hear a rattiling noise. I first thought it might be the jate rings but have ruled that out, nothing seems to be loose and the truck has had some of the steerting componets replaced. Seems like it is coming from the drivers side could it be a cv joint? Doesnt seem like it could be at this point but Ihave yet to determine. I have gone over the truck and tried to make sure every possbible bolt in the area that could be loose is tight. I am out of ideas... Any ideas
Old September 11th, 2005, 06:53 PM
spare tire carrier.
Old September 11th, 2005, 07:33 PM
I usually dont have the tire on the spare carrier, rarely ever. its coming from the front of the truck..
Old September 11th, 2005, 07:41 PM
Does it happen when turning? Stopping? Under load while accelerating? or when in neutral or down shifting?
Old September 11th, 2005, 07:43 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Could well be the hood hinges--it took me forever to figure this one out on mine. With the hood close, pull up on the corners of the hood by the windscreen and see if there is any play. A block of wood and a hammer and I "tightend" the metal loops that go around that plastic bit and all noise went bye-bye.
Old September 12th, 2005, 09:29 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Cats? Had a rattle forever and it was the cats.
EwS
Old September 12th, 2005, 10:52 AM
nah I dont think cats, it just occurs when traveling over rough terrain independent of the wheels being turned or not. the CV's have never made noise and dont leak fluid.
Old September 12th, 2005, 12:46 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Do you have spacers on your springs? I have one on the drivers side and when off road the spring will unseat slightly and reseat makes a ratteling noise.
Jimmy Buffett
Old September 12th, 2005, 04:07 PM
ronward's Avatar
ronward
Redsrover
None - sadly
I have the same symptoms, turns out its the roller fairlead on my Warn winch up front. The rollers on the bottom, top and left side are loose since the cable is hooked to the right side dixon-bate tow jaw. Vibrates pretty loud on gravel, might be your issue.
Anything is possible, with the right tools...
Old September 12th, 2005, 05:43 PM
no winch all stocker. thanks for the ideas..
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
lifted d 90 noise 4x4x46 Defender Technical Discussions 11 June 15th, 2005 07:29 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
