A fix for aftermarket radio in D90 - Defender Source
Old September 28th, 2011, 05:22 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
I got tired of searching for a solution for being able to use a aftermarket radio in my truck, without cutting or splicing into the factory harness. My solution was to get a radio out of a D1 take it apart and use the connector off of it. The Disco plug in has 3 spaces and the Defender only has 2. The 2 outside one are the ones you need to use. First you will have to take a soldering iron or a small butane torch and un solder the old circut board. leaving the terminal ends exposed. I have the drawings of how I soldered which wire where. I will post these after I get back from MAR. It is a little tedius but at least my factory harness is not compromised.
Old September 29th, 2011, 02:12 PM
esprit99's Avatar
esprit99
Keith Imbriglio
1997 D90 SW Arles Blue
Metra makes a plug in harness 70-9400. Plugs in with no cutting http://www.metraonline.com/part/70-9400 about $20. The harness in the truck is from a VW.
Life is to short to drive ugly cars
'97 D90 SW #2251 Arles blue
'16 RRE
'04 Disco
Old September 29th, 2011, 04:16 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Yep, or you can completely run all new wiring which if done correctly will sound better anyhow.
Old September 30th, 2011, 01:10 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Does anyone know how to splice the D1 plugs onto the original harness? The harness in my '95 was cut for an aftermarket radio and I want to return to the original. I can't locate the original plugs, but I picked up a set of D1 plugs. Are the wire colors the same?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old July 6th, 2012, 12:57 PM
George, did using the disco plugs work for you? I'm in the same boat on my 94.
Originally Posted by pendy
I'm here for the D's
Old July 6th, 2012, 02:01 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Hey Charles - Sad to say that I haven't tried to do the splice yet, but the plugs will definitely work. I had a conversation with John at Roverville a while back and he confimed this. The pink plug is for the speakers. Top row is the positive and the bottom row is negative. Not sure which column applies to each speaker. It will take a little trial and error. The D1 harness also has a black and gray plug, but I don't recall off-hand which one is used for the Defender radio. It should be apparent when you see it as it has the black ground wire. My notes are incomplete, but I think the top right wire on the plug is power when the key is turned to on. The purple is constant power. Not sure which wire connects to the amp.
When I get into it I'll let you know.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old July 6th, 2012, 02:03 PM
Thanks. I really just wanted to know if the plugs were the same. I can trace the wires since I know what's what on the adapter side, and will document them if I beat you to it.
charles
90, d90, radio
Which Radio plugs work in 95 D90? Gkase Defender Technical Discussions 11 July 25th, 2011 12:41 PM
'97 NAS D90 Radio sekmar99 Smaller Projects 2 January 23rd, 2011 07:39 PM
D90 radio harness needed Gkase Wanted 7 September 5th, 2006 05:12 PM
'97 D90 radio install help Defender50th Defender Technical Discussions 0 October 18th, 2005 03:19 PM
D90 Clock Rejuvinated - One fix arbik Defender Technical Discussions 0 March 2nd, 2005 07:34 PM
