A few electrical questions - '92 tdi - Defender Source
Old September 21st, 2010, 02:10 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
so - a 92 200tdi UK D110
Did the LHD conversion and managed to wire up the TD5 warning light cluster. But a few...wtf....moments occured during this process and was hoping y'all could help.
First - are there ANY better schematics than these POS's that seem to be all that's out there. I was somewhat surprised - and amused - to find that when you break it down, it is very similar to the 2002+ color schematics that are out there broken into circuits, but this thing is a mess. Plus, I can't for the life of me find the key/schematic to "#35 - Steering column switches". Seems a big piece to be missing. Also, the selector switch that is mounted under the binnacle that turns the interior light on and off isn't in this schematic - so what else is missing?
Second - the lights. No issue per se. When I move the light selector to parking light on, the main head lamp, after a few seconds, comes on in a dim setting. How is this done? The only schematic I can find show this "Voltage Transformer" - now the last time I checked, transforming DC voltage isn't that easy to do. You either use a resistor- down voltage only, a switching DC power supply(not really 1986 technology), or an occilator followed by a transformer follower by a rectifier. I did find a relatively large resistor up under my right wing. Is this the 'transformer'?
third - the low fuel level light. At first, I just connected the white/slate (WS) in the harness. Then I found a little circuit board wrapped in foam further back in the dash harness - about 3/4" x 2". It had a green and black wire going in (ign power and ground) and WS wire coming from it - I assume this is a resistive comparator circuit that opens a gate at a certain level to turn on the light. But there is NO record of this little gem anywhere I can see. Anyone ever seen this? Any part number or schematic out there? Haven't gotten low enough to see if the thing even works yet.
I'll try add the pdf's that I've been working from
OK, thanks
Old September 21st, 2010, 02:36 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
The voltage transformer thing was fitted to rovers over here around the 1990's.
What it did was... if you selected "dipped beam", that is, full headlights, with the igniton on, then you got full lights.
If you turn the ignition/engine off, the headlights go out, but the small sidelight/marker lights stay on.
There was a rule in the UK road laws that said you couldn't drive with such small marker lights on, so as such, if you try having just "side" lights on with the ignition, the voltage transformer gave 1/10 voltage to the headlights, giving them that dull glow. there should be a large wire wound resistor bolted up in the RH (i think) fender which does the voltage reduction, and a relay up under the dash to control all of this shenanigans.
you can just pull the relay out and be done with it, so reverting back to main, side or off. (later rovers don't have this, as the rules changed)
electrical, tdi
300 Tdi Electrical Diagrams AggieD90 Defender Technical Discussions 10 June 22nd, 2008 06:46 AM
300 TDI D110 Engine Questions SOUTHPAW26 Defender Technical Discussions 6 June 1st, 2008 06:19 PM
Tdi electrical diagram artm Defender Technical Discussions 2 January 13th, 2006 08:52 PM
300 Tdi fule leak Questions!! Buckon37s Defender Technical Discussions 13 February 28th, 2005 02:32 AM
