A couple brake questions - Defender Source
Old April 19th, 2010, 03:52 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
I'm currently working on the brakes on my build, and am curious about proper routing of lines and proper terminals for the master cyl. I'm using a D90 NAS master, which has 3 outputs, one near the servo on the left side, and two at the end, one on the left and one on the bottom. I presume that one goes to the rear, while the other two are for the front. Does it matter which goes where? I think I plumbed it so the "rear" one is going to the rear, while the other two are for the front. No doubt someone will correct me, and I'll have to do some reflaring... which just drives me wild.
I feel like there should also be some kind of proportioning valve on there too.
I bought some stainless brake lines (actually, I couldn't find stock ones), and was wondering if these connect directly into the calipers, or if there is a hardline that should be on the caliper connecting to some bracket that I don't have. I remember the RRC calipers I took off had something like that. Any chance someone could help me out? Any one have a picture of their truck w/o the wheel on? Many thanks!
-Ethan
brake
New Owner -- Couple of Questions Duke D90 Defender Technical Discussions 17 February 7th, 2010 01:41 AM
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
New Owner with a couple of questions. 97-D90-736 Defender Technical Discussions 13 May 29th, 2009 08:15 PM
