A/C wiring diagram - Defender Source
Old August 18th, 2004, 04:22 PM
Shane@EVS
Roverhybrids
A/C wiring diagram
retrofitting an A/C system for a NAS D90 to the D100 hybrid with a 200tdi wiring harness and a 97 disco compressor. I have two plugs that I can't figure out exactly.
2 prong plug:
both approx 12g wire
purple w/ gray stripe
brown w/ white stripe
6 prong plug:
blue/black stripe
blue/white
gray/blue
yellow/white
gray/black
green
the relays are connected to the side of the under dash unit.
I'd guess the 2 prong plug is for two constant hot wires, based on the color?
green wire ignition switched hot?
the others?
Old August 19th, 2004, 06:47 PM
Shane@EVS
Roverhybrids
please
Old August 20th, 2004, 08:29 AM
You may want to ask Martin Podgorski ( http://www.defendersource.com/forum/members/mpodgorski-65.html ) I think he may be able to get you one.
Old August 20th, 2004, 08:46 AM
mpodgorski's Avatar
mpodgorski
martin
'94 D90 ST Arles
i can help, all i need to know what system you are trying to fit in. I have the diagram for the Elite.
I can fax you a copy. Just let me know.
m
wiring
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C Wiring Diagram 97 NAS? dmb Defender Technical Discussions 2 April 8th, 2006 02:14 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
hella wiring diagram Campbell Defender Technical Discussions 1 May 1st, 2004 02:28 PM
300tdi Wiring Diagram? JimC Defender Technical Discussions 20 April 7th, 2004 09:39 AM
