A/C upper hose replacement on a 1997 system - Defender Source
Old August 7th, 2015, 10:17 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
I searched and found some info but wanted to see who has had a hose built as a replacement. I know they are NLA to buy new and I had the lower one rebuilt but the upper hose that comes from the compressor to the condenser is a bit different. Any advice how to approach this.
Thanks in advance!
Old August 8th, 2015, 09:56 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I had a problem finding a hose for a 110 build. I ended up taking the hose to a line shop and had them just replace the rubber line.
Old August 9th, 2015, 04:33 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Thanks Mike. That helps to know it is possible to reuse the metal fittings. I hat type of hose shop did you take it to?
Old August 9th, 2015, 06:52 AM
Capt Milks's Avatar
Capt Milks
I found a small shop that did hydro lines for tractors but he also did a/c lines. You have to cut off the clamp rings but he had the correct size hose and rings. The hard line fittings are not as common and I could not find anybody that would make up them up. As it turned out replacing the rubber lines was easy.
Old August 9th, 2015, 05:51 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
That helps. Hoping I have the same luck here. Thanks!
Old August 9th, 2015, 06:03 PM
I had the line from the compressor to the evaporator, and the line from the evaporator to the receiver dryer rebuilt. I just gave them the old ones and they made me two new ones with new fittings. The new hoses were slightly larger because the originals are single barrier.
Old August 10th, 2015, 02:42 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Thanks for the help. So to those who have had the high pressure, the upper one from the compressor to the condenser, line rebuilt did the shops just have the proper fittings? Went to a shop today and they said it's going to be hard to find a fitting that will match the compressor on a 1997. So now we are trying to see about how to best make this work. Did your shops have the fittings?
Old August 10th, 2015, 03:46 PM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
I bought a kit from an online automotive AC site that has a crimper and you can buy the collars and hoses as well. For my '93 D110, I rebuilt all the rubber lines with this system and they all work fine so far. I was able to re-use all the old fittings as the hose can be carefully cut from them and then the fittings re-used. I assume your '97 would be the same.
So yes - they can re-use the fittings just be careful when you remove the old collars and hoses.
http://www.autoacsystems.com/_faqs/d...oserepair.html
AndrewT
'93 NAS D110 #437
Old August 10th, 2015, 07:09 PM
Do you not have the old lines?
Old August 10th, 2015, 07:40 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Thanks! After trying 6 places today finally found a shop in town that can reuse the fittings and replace the rubber hose. So we should be good.
Old August 10th, 2015, 08:00 PM
FWIW, mine had leaks in the hard lines, not the rubber. The local a/c shop was able to make complete new lines for me.
1997, 97, ac
1997 A/C upper hose Tyler Wirken Wanted 0 August 7th, 2015 10:13 PM
Fuel Hose...yep hose. wcampbel@nas.edu Defender Technical Discussions 0 January 9th, 2012 05:22 PM
Is the AC compressor on a 1994 style system the same as a 95 style system? evilfij Defender Technical Discussions 0 May 31st, 2010 06:20 PM
Power Steering Hose Replacement CDeWan Defender Technical Discussions 1 January 20th, 2009 09:31 PM
Air intake hose, fuel filler hose and neck SafariHP The Vendors Loft 0 May 18th, 2008 08:52 PM
