A/C troubleshooting help Sought... - Defender Source
Old August 28th, 2008, 07:50 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Summer is almost over, but I still need to figure out what went wrong with the A/C while the Defender was in storage for three years. It does not appear that the A/C system is engaging the compressor's clutch, as I don't see it spin when the A/C is turned on. I don't see any obviously disconnected harnesses, and I tried 'reseating' the plugs and connectors I could see. Any thoughts? Do the clutches go bad frequently, or is it more likely electrical (in a Land Rover, who would think?!?)?
Interior fan works fine, except it blows alot of hot air...
~Scott T.
'95 D-90 ST - AA Yellow
Old August 28th, 2008, 07:53 AM
Have you checked the pressure in the system? Its very common to lose refrigerant when a car is stored that long. If the pressure is low, the trinary switch will prevent the compressor from engaging.
Old August 28th, 2008, 08:08 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Yeah, the trinary gear . . . that's what I was going to say
Old August 28th, 2008, 09:46 AM
x2. if your pressure is fine, I would suspect electrical. I've never heard of an A/C compressor clutch go bad. They're pretty reliable.
ht
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
A/C unit Ray Bone Defender Technical Discussions 2 June 7th, 2005 06:46 AM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
A/c question Campbell Defender Technical Discussions 3 April 21st, 2004 04:41 PM
