A/c stinks when it first comes on - Defender Source
Old May 12th, 2009, 12:44 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Any ideas.
Old May 12th, 2009, 01:27 PM
Depends on what is smells like.
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Condensate in your system.
Old May 12th, 2009, 01:40 PM
I would clean your vents....
Old May 12th, 2009, 01:55 PM
madcowdungbeetle
Carter
Sounds like water or moisture is collecting and mildew is growing. Try cleaning the drain, it may be plugged up.
Old May 12th, 2009, 03:50 PM
Clean the drains and make sure the water is coming out the bottom. Once you have done this, spray a ton of lysol into the vents and the intake.
Old May 12th, 2009, 10:19 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Summer is coming, take the all damn thing apart
and give it a good clean. I just did to mine and
got scared with the amount of dirt, it was clogged
with a black damp spongy stuff .
- Charles Eames
Old May 13th, 2009, 08:00 AM
Campbell's Avatar
Campbell
Rich Campbell
Will do thanks.
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
A/C blower motor Campbell Defender Technical Discussions 3 September 9th, 2004 11:01 AM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
Leaking A/C Ragland Defender Technical Discussions 3 May 24th, 2004 10:40 AM
