A/C low and high pressure lines - Defender Source
Old January 5th, 2015, 02:57 PM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
Hello all! My low pressure line on the dealer installed A/C. In my '95 D90 has a slow leak. Anyone know how to source a hose? I have read that it is hard as there where many A/C kits for a dealer to choose.
Also if I replace the low line, should I replace the high pressure line too at the same time?
Thanks in advance!
Old January 5th, 2015, 03:01 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I would check with Rovers Down South. Also a good hydraulic shop should be able to make up a set for you.
Old January 5th, 2015, 04:12 PM
petminded's Avatar
petminded
David
Thanks!
I have a good hose place here in Huntington Beach. This is a big car city with lots of specialty shops. But I'm trying to avoid going to a custom hose shop as they normally cost double and I would need to tear the hose out first to get it matched and fixed.
I will call Rovers Down South right now. Is this the one: http://www.rdsparts.com/ ?
300 tdi injectors - high pressure injector option for replacement? nathanwind Defender Technical Discussions 14 July 7th, 2017 03:00 PM
Pin Layout high/low pressure switches anfonee1 Defender Technical Discussions 4 July 20th, 2014 07:38 PM
high/low pressure oil line leak ? aosias Defender Technical Discussions 3 June 8th, 2012 09:17 PM
Source for hard line (High pressure bypass?) on steering box? KevinNY Defender Technical Discussions 17 October 29th, 2009 11:33 PM
NAS 110 A/C High Pressure Valve Mikenbama Wanted 6 September 1st, 2009 02:30 AM
