A/C Install - Defender Source
Old September 30th, 2006, 08:43 PM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
A/C Install
I just got a used A/C for my 95. I am fairly sure it is a Wynns unit and it came out of a 95. I am fairly mehcanically inclined, however, I work best with a set of instructions. I purchased a CD from Land Rover Classics with workshop manuals etc, but they don't have specific instructions. Do any of you guys that work at a dealership have any kind of instructions for the install, or does anyone else have instructions? Thanks for the help.
Old October 1st, 2006, 07:27 AM
btate
Bryan Tate
d90
I may have what you need. When I get home I will check.
I was having some troubles also, someone sent some instructions, but not sure which unit I have the instructions for. I believe it is for a 95 kit from RN....
Old October 1st, 2006, 12:40 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
those were my instructions and they were indeed for a 95 kit from RN...Adam, if Bryan can't find them let me know and I can fax you a set
George
Old October 1st, 2006, 01:14 PM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
Thanks, any chance you can scan an email them? If not, I'll try and find a fax machine.
Old October 1st, 2006, 04:41 PM
Gkase's Avatar
Gkase
George Kase
Maybe Bryan converted them to digital? if not I'll send you a xeroxed set via snail mail...PM me your address...
I wonder if it would be worth converting them to digital anyway for posting on this site? anyhow, let me know...
George
Old October 1st, 2006, 05:01 PM
Sorry to hijack this thread, but does anyone has any info about converting their AC from R12 to R134A? Does anything have to be done (like a conversion kit) or can you just change over?
thanks
charles
Old October 2nd, 2006, 01:32 AM
Gkase's Avatar
Gkase
George Kase
I don't know...must be a rather universal question around all the car groups though...as to what I have heard (worth what you paid for it) you just buy a 134 recharge kit and you're good to go...In my past, I took the car (my BMW) to a shop that does AC and asked them to change it over...cost like $250 bucks as I recall...and has been working for about 4 years...
Old October 2nd, 2006, 12:41 PM
khouseal's Avatar
khouseal
Kevin Houseal
1994 NAS D-90
Let me know if you don't find a copy, I've got one at home.
Kevin
Old October 2nd, 2006, 12:50 PM
Gkase's Avatar
Gkase
George Kase
AC instructions are on the way...
George
Old October 2nd, 2006, 01:42 PM
If someone would scan them it would be appreciated as I am planning to remove my 95 style AC.
Ron
evilfij at yahoo dot com
Old October 2nd, 2006, 02:18 PM
Gkase's Avatar
Gkase
George Kase
Ron...do you have access to a fax machine?
Old October 2nd, 2006, 02:23 PM
Ah, not really.
Old October 2nd, 2006, 02:30 PM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
Thanks for the help guys, I'll let you know how it goes.
Old October 2nd, 2006, 02:36 PM
Gkase's Avatar
Gkase
George Kase
can anyone give me some guidance on what settings to use to scan a set so they'd be legible via email and then I can just email these out to folks...
Old October 2nd, 2006, 02:56 PM
Just scan and convert to PDF. Should be fine to read via email.
Old October 2nd, 2006, 03:04 PM
TXRover
Joseph Reseland
If you don't have to convert from R12 to R134, don't do it. The oils that the two different refrigerants use are not compatible (among other things). If you are mechanically inclined, get EPA certified for R12 ($20 course on-line) and buy R12 on e-bay for less than $20.00/lb. You can then pay someone to evacuate and refill the system, or do it yourself with the proper equipment. Don't let anyone tell you that it is as simple as changing the fittings, it is much more involved than that.
My 2-cents,
Joseph
Old October 2nd, 2006, 03:10 PM
Thanks Joseph
Mine has a slow leak somewhere and I assume is empty (haven't used it in a year). If I don't want to go the certification route, I assume I'm just going to have to pay shop prices to get the leak fixed and it filled then. Bummer - was hoping a change to R134 would be easy and something I could do.
I have heard the A/C compressor would make a fine OBA pump. Perhaps thats a better use for it
thanks
charles
Old October 2nd, 2006, 03:20 PM
Ah, 94 and up D90 ACs are all R134 only 110 AC is not.
Old October 2nd, 2006, 04:05 PM
Gkase's Avatar
Gkase
George Kase
Ron...no way I've got the time to scan all these pages and convert to pdf...but I'll send you a xerox...pm me your address and I'll ship it off to you also...
George
Old October 2nd, 2006, 06:46 PM
Wow. I checked the side of my compressor and sure enough its HFC 134! But I *thought* mine was R12 since the '94 manual I have says so. I checked my 95/97 manual and it says R134. Go figure.
Thanks Ron! I have already smacked myself for not checking the compressor first.
charles
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C install help Heath Defender Technical Discussions 4 August 28th, 2006 09:41 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
A/C unit Ray Bone Defender Technical Discussions 2 June 7th, 2005 06:46 AM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
