A/C Install - Page 2 - Defender Source
Old October 3rd, 2006, 10:42 AM
CGunther's Avatar
CGunther
Christian Gunther
'94 D90
If someone wants to fax them to me, I can scan them and email them in a couple of minutes. PM me and I will get a fax number to you.
Vroom.
Old October 3rd, 2006, 01:05 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Christian...I PMed you for your number...I'll fax you a set...
George
Old October 3rd, 2006, 02:48 PM
CGunther's Avatar
CGunther
Christian Gunther
'94 D90
I have the .pdf if someone wants it or if CVC wants to post it somewhere. (608k) PM me with an email and I will send it out ASAP.
It is really easy for me to do this. If anyone needs this done for other installs, let me know. Also helps with my library.
-Christian
Vroom.
Old October 7th, 2006, 08:21 AM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
Alright, I'm just waiting for some new hoses, and the instructions that George sent were great. I am trying to install the blower/evaporator into that goes in the passenger footwell, and the instructions mention a special bracket that looks like it slides between the dash and the firewall, with some studs on it for the evaporator unit. The guy I bought the AC from said his truck didn't have the bracket and the unit itself has a flange that looks like it could slide up there, but is definately not the bracket. Here is the picture from the instructions. The yellow rectangle highlights the mysterious bracket, and the red circle highlight the studs welded onto the firewall.
OK, with all that being said, does anyone else with a Wynn's system have this bracket on there unit?
Thanks for all the help.
Old October 7th, 2006, 08:39 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
If you do manage to get it to pdf format, let the group know. I for one could use a copy.
Old October 7th, 2006, 01:19 PM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
Nevermind, I finally looked at it and it was attached to the evaporator. Duh...
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C install help Heath Defender Technical Discussions 4 August 28th, 2006 09:41 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
A/C unit Ray Bone Defender Technical Discussions 2 June 7th, 2005 06:46 AM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
