A/C in SW - Page 2 - Defender Source
Old December 23rd, 2012, 02:57 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
My 95 SW with factory air is my daily driver in New Orleans. There was a period when I needed a new belt to the AC compressor and when it slipped and wouldn't engage I knew it real fast because I would start dripping in sweat and would need to close the flap on the center console to keep from getting water damage on my stereo.
When the AC is on, I always keep it on full cold and highest fan speed and it does a damn good job at keeping the truck cool. It helps a ton if your truck isn't hot as hell when you get in (by parking in garage) because it isn't great at cooling off a hot truck. I have also gotten obsessed about reducing cabin heat, with dynamat, and I had my manifolds ceramic coated.
Old December 23rd, 2012, 05:02 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Thanks for the continued advice on the SW AC. Sounds like the dynomat is the way to go for sure in a SW.
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old December 23rd, 2012, 06:51 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
I just put in a unit from Safari. It was a little pricey, but it went very easy and works excellent. The first day I drove it was over 80 and was cool inside.
Old December 23rd, 2012, 07:10 PM
DGH
David Howe
Be careful or you know who will be saying, "this 90 was too hot, this one was too cold..."
2011 LR4 Metropolis (white)
2003 DII Santorini Black (I think)
1981 FJ 40 Beige
Defender - in the market
Old December 23rd, 2012, 07:22 PM
Next you'll be worried about getting a callous on your hand from changing gear in a stick shift.
Old December 23rd, 2012, 08:08 PM
bjf's Avatar
bjf
barry f
94 ST #395
The lt77 hurts to shift. The r380 is just right...
Old December 23rd, 2012, 08:24 PM
Only with redline MTF rubbed into your palm daily ...
Old December 23rd, 2012, 08:55 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
I never ran AC in mine and I don't have working AC in any of my other cars. When i ran The AC to test it in my SW it was Cold! I've never had an issue of in the 80-90* F NY summers with humidity in either of my rovers. But then again I roll around Phoenix at 110*F with the windows down.
97 D-90 SW A/C drier help blenkush Defender Technical Discussions 0 June 21st, 2011 11:41 PM
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C busted on '97 SW smob Defender Technical Discussions 1 May 29th, 2010 11:06 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
