A/C Help......hot, hot, hot! - Defender Source
Old August 19th, 2006, 09:33 AM
boulderbear's Avatar
boulderbear
Barry
'97 D90
A/C isnít working and hereís what I have so far - nice toasty air coming out of the vents, clutch on the compressor is not engaging and the auxiliary fan in front of the radiator isnít coming on. Both A/C fuses under center consol are good.
Any idea which (if any) of the relays behind the coin tray belong to the A/C (pic below)........or where the Compressor Clutch Relay is located? I see it on the schematics, but it doesn't mention location. Someone on D-web mentioned passenger side firewall - I'll look there this morning.
My guesses are the relay or the A/C switch may be bad......am I one the right trail? Would low refrigerant keep the compressor from kicking in?
HelpÖÖ.it was 103 yesterday!
Old August 19th, 2006, 04:19 PM
boulderbear
Barry
Turns out it's a leak in one of the lines heading out of the condenser - anyone know where to get a new line?.........I can't find them online or in the catalogs of the usual suspects.
Old August 19th, 2006, 06:56 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Get ready for an odyssey rivalling the Lord of the Rings. Fortunately you don't have the Diavia unit in a '97. Perhaps it won't be that bad.
Looking back, I should have just junked my old unit and bought a Wynn kit from RDS. I replaced the compressor and reworked some other parts. The A/C still isn't very cold. Then again, nothing really works against the heat coming through the floor.
"Uhh...I think they all leak like that."
Old August 22nd, 2006, 06:44 PM
boulderbear
Barry
SUCCESS
Found the leak
Took the offending line off
Stealership quoted $380 to replace the line (part only)
Local A/C shop welded two holes in the aluminum tubing, replaced the rubber tubing & correctly crimped it in place, replaced the O-rings and cleaned the whole thing up like new............$48
Very nice work and done in less than 2 hours!!
I put the line back on & charged the system..........all is cool in the cab!!!!
I would have gladly paid double..............don't tell them
Old August 22nd, 2006, 08:04 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Mine just died too, but I have yet to inspect.
What was up with the compressor not engaging? Mine I think is acting that way.
Old August 22nd, 2006, 08:16 PM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
it was probably a low pressure Freon kill switch...if there is no coolant in the system the compressor does not come on. I know it works that way on Disco and since I sold my 97 LE I can't go check, but I am sure that is the way it is on a 97 D90.
Old August 23rd, 2006, 05:14 PM
boulderbear
Barry
wicks, Irnas90 is right.........if there is not enough coolant the compressor clutch will not engage.
Old August 26th, 2006, 07:54 PM
wicks's Avatar
wicks
Wicks
It was just the dash fuse! All cool again.
Running Hot with a/c on Campbell Defender Technical Discussions 44 September 2nd, 2011 06:22 PM
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
A/C wiring diagram Shane@EVS Defender Technical Discussions 3 August 20th, 2004 08:46 AM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
