A/C + heater problems - Defender Source
Old November 6th, 2012, 05:02 PM
melittle
Mark Little
1987 Land Rover 110
Here are a few of the symtoms I'm currently encountering (LHD disco 200tdi conversion)
HEAT - pretty much none. Only blows slightly warmish air when up to full operating temperature which could easily be from the hot air in the engine bay.
FAN - blows very weak on speeds 1,2,3, then full blast on 4).
AIR DISTRIBUTION LEVER - doesn't do anything, air only blows out of top vents at the windshield no matter what position it's in.
AC - not cold, or even cool. Fans in front of the radiator do come on when I push the AC button.
VACUUM HOSES - One of the red vacuum hoses to the top of the AC/Heater box is dangling. Can't find any diagram that shows what it's supposed to connect to.
Is this 5 different problems or do these symptoms sound like something with a common cause?
Thanks for any help on any of these issues....
Mark
Old November 6th, 2012, 05:10 PM
Do you have the big box that has box AC and heat with the AC vents in the dash where the vent levers would be on another truck?
If so, I suspect you have several problems.
Old November 6th, 2012, 05:24 PM
melittle
Mark Little
1987 Land Rover 110
Yes.
Name:	Screen Shot 2012-11-06 at 2.21.52 PM.jpg
Old November 7th, 2012, 12:32 PM
melittle
Mark Little
1987 Land Rover 110
LHD factory A/C vacuum hose routing
Does anyone have a diagram of the vacuum hose routing for the 1987 LHD A/C unit? Or a picture of where the red hoses attach?
Thanks.
Old November 7th, 2012, 01:09 PM
Pretty sure the red hose goes on 14. Everything in the system is operated by vacuum bellows.
Old November 7th, 2012, 03:02 PM
melittle
Mark Little
1987 Land Rover 110
It's connected at the AC/heater box, the other end is not connected to anything. I'm wondering if this could be one of the hoses that are supposed to be connected to #4 in the attached diagram? I'll try to take a look and see if all the connections look good on the back of the heater controls....
Name:	Screen Shot 2012-11-07 at 11.54.10 AM.jpg
Old November 7th, 2012, 03:24 PM
Seriously, there are lines everywhere. My Guess would that it goes to the scoop thing under the fender (there is a flap operated by a bellows to cut off incoming air), but I don't recall where all the colors go.
You can also take the grey vent holding thing off easy enough and then get access to where all the lines connect. I would suspect some of the bellows stopped working as well.
heater, problems
Rear A/C or heater duct blenkush For Sale - Parts 1 September 11th, 2013 10:23 AM
Factory A/C plumbing and heater matrix? fraser61 Defender Technical Discussions 2 December 28th, 2010 08:14 PM
Defender rear A/C or heater ducts blenkush For Sale - Parts 9 December 13th, 2010 10:17 PM
A/C and heater question Overlander Defender Technical Discussions 9 January 19th, 2008 08:50 AM
heater core replacement with A/C beck427 Defender Technical Discussions 4 November 30th, 2006 03:19 PM
