A/C fuse keeps blowing - Defender Source
Old September 11th, 2010, 09:08 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I have a 97 D90 SW that keeps blowing the a/c fuse and the air will start blowing hot. At first I thought it was a short but now I realize it only blows when I turn it up past #1 on the blower dial. As long as don't turn the A/C up to #2 or 3 it will not blow the fuse. Simple answer right?..... don't turn it past #1.
However I also think it feel a slight pull on the engine when I have the a/c on.
Thoughts? Is my compressor motor going out? Its not making any noise.
Old September 11th, 2010, 09:26 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Likely your blower motor on the way out, or something bad in the blower resistor.
If it is blowing fuses as you put increased electrical load on the blower motor then that points to it being the issue.
Email:
Old September 11th, 2010, 12:03 PM
Reese_D90's Avatar
Reese_D90
Reese
Is replacing the blower motor an easy item? Did I read somewhere that its NLA?
wing
15A Fuse keeps blowing. KKilo23 Defender Technical Discussions 36 June 12th, 2017 06:36 PM
A/C fuse jblieb Defender Technical Discussions 7 September 23rd, 2005 12:06 PM
Repeatedly blowing undehood 30A fuse Hans Defender Technical Discussions 1 September 6th, 2005 04:24 PM
Blowing wiper/speedo fuse like crazy....help! P1CR Defender Technical Discussions 4 March 11th, 2004 03:23 PM
