A/C Freon and conversion advice - Defender Source
Old August 12th, 2014, 03:13 AM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
This weekend I went to the mountains and it got hot and toasty inside my cab. It was bearable until I was following 2 Jeeps and had to suck in all their dust.
Now back at home and knowing my 95 NAS has dealer installed A/C I wanted to get some details about it and see what it would take to get it up and running again.
I assume I will need a new charcoal filter, but what about converting to newer coolant? I did some searches and I figured I was searching under the wrong words.... or its not possible as everyone else knows so. I found one thread about how to diagnose A/C issues, but thats it.
Also, if I do get the A/C back on line, any tips/suggestions that make the deal installed A/C better?
Old August 12th, 2014, 06:45 AM
I am not sure you aren't already charged up with R-134a. If you still have the old Freon then you will have to take it somewhere to have the old stuff flushed and the new coolant put in.
Old August 12th, 2014, 07:21 AM
A drop curtain would probably be a good idea to help it work better.
I would go get the a/c charged to start with so you can diagnose it from there.
Old August 12th, 2014, 07:43 AM
Check the fuse and recharge it, see if the compressor begins to spin. If it does and it's warm a few days later it's warm or the compressor stops, then it's time for dye for leak diagnosis. Search R-134a here and you should find more threads.
Old August 12th, 2014, 12:14 PM
petminded's Avatar
petminded
David
Thanks all! It's in the shop today.
Old August 12th, 2014, 04:33 PM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
Refrigeration technician here:
Just for the hell of it, give us a report on what they did and what they charged you.
Thanks!
Old August 12th, 2014, 05:06 PM
petminded's Avatar
petminded
David
Will do. Keep in mind that here is So California the going rate for labor is 100 to 120 an hr.
Old August 12th, 2014, 05:29 PM
DannyboyUpstate
Danny Harrington
1983 110 3-door
Same here in NY unless you go to Billy Bob's Auto.
Old August 12th, 2014, 06:49 PM
Automotive?
FWIW, at the dealer we charge 1.5 hours labour to evacuate, recharge, and find leaks in a/c systems.
Old August 12th, 2014, 07:25 PM
petminded's Avatar
petminded
David
Does anyone know for sure if the 1995 deal option a/c has r12 or the r134a?
Old August 12th, 2014, 08:13 PM
Mine is R134A and is a dealer installed kit. There are multiple different versions of the a/c kits that were installed at the dealership. Mine is a Wynnes unit IIRC.
Old August 12th, 2014, 08:15 PM
DannyboyUpstate
Danny Harrington
1983 110 3-door
That's right on the edge of the phaseout date. Could go either way.
Old August 12th, 2014, 08:21 PM
petminded's Avatar
petminded
David
Should I be looking for a manufacturer name or something that would let me know one way or other? Or are the high/low stems a special size if it's one or the other?
Old August 12th, 2014, 08:24 PM
Can you post some pictures? The ports are different.
Old August 12th, 2014, 08:50 PM
DannyboyUpstate
Danny Harrington
1983 110 3-door
http://www.aa1car.com/library/ac_service_fittings.gif
Old August 13th, 2014, 04:03 AM
petminded's Avatar
petminded
David
Thanks!
It's r134....
Old September 14th, 2014, 12:03 AM
petminded's Avatar
petminded
David
PS: it cost $69 to get my a/c working. All that was needed was the r134! And I am AMAZED as the a/c has not worked since 2002.
Old September 14th, 2014, 12:08 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Freon isn't used up in ac, it's an energy carrier... If you need to recharge then you have a leak.
Old September 14th, 2014, 09:58 AM
That is true, but sometimes the leak is so small just recharging it will do the trick. I recharged the a/c in my Disco in 2006 and it was still working when I sold the truck in 2012.
Old September 14th, 2014, 12:15 PM
jafir's Avatar
jafir
Jafir Elkurd
Also it can be pretty hard to find the leak if you don't charge it up first.
ac, advice, conversion
SW to ST to SW Conversion Advice SMac Misc. Chit-Chat 11 April 13th, 2012 11:31 PM
Last minute advice - Belt Rail conversion? jkins Defender Technical Discussions 1 March 11th, 2012 12:41 AM
Advice on chassis and engine conversion project Rovermn Defender Technical Discussions 0 August 12th, 2008 10:08 AM
110 tried almost everything and it is still overheating.need some advice draaronr Defender Technical Discussions 21 November 17th, 2004 07:25 AM
First Post Here - D90 Audio Wiring and Advice Kimos Defender Technical Discussions 3 October 12th, 2004 01:17 PM
