A/C freezing up - Defender Source
Old June 22nd, 2008, 09:52 PM
A/C freezing up
I have a late model underdash A/C (same as RN kit) and I have noticed that it freezes up after about an hour of operation, at which time the blowing air dwindels to zilch with the fan on high. I have to turn it off and let it melt off for about 30, before I can turn it back on again. Any ideas why it's doing that and any kind of resolution?
Old June 23rd, 2008, 10:46 AM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Have you tried adjusting the cold level? I assume you have two variable switches, one for fan speed and the other the cool level. Before mine was overhauled, it would freeze when at the coldest setting.
"Uhh...I think they all leak like that."
Old June 23rd, 2008, 10:58 AM
Mine freezes at lowest setting. Research I did last night after posting this is the likely cause is either a bad low pressure cycling switch, insufficient refrigerant due to a leak that also introduced moist air, or a bad expansion valve. I'm going to have it looked at by an ac mechanic.
Old June 25th, 2008, 12:33 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Mark,
mine does the exact same thing...my new AC guy says it's probably because the previous shop that filled it with R132 probably didn't evacuate correctly...he thinks he can redo the freon install and solve the problem. keep us posted on your findings.
George
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
A/C unit Ray Bone Defender Technical Discussions 2 June 7th, 2005 06:46 AM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
A/c question Campbell Defender Technical Discussions 3 April 21st, 2004 04:41 PM
