A/C Condensor Fan Operation - Defender Source
Old July 18th, 2006, 09:53 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
Hey everyone Question about your condensor fan operation on the 1997 D90(don't think the 94-95 is the same cause the fan is triggered by the ecu reciving a ground signal, but i could be wrong). I replaced mine because it was frozen up. Now when the a/c is on, according to the wsm, the condensor fan should be running. But if you read the info about the circuit operation thru the trinary switch, it says the contacts close above 305psi on the high side. Trying to figure out if the trinary switch is bad, or if the condensor fan only runs when the vehicle is hot and pressure is really high...I know it is supposed to kick in if the engine overheats. Anyone who would take the time to verify whether their fan runs everytime the a/c is on or just when needed would be appreciated...The fan runs once in a while on mine....
jeff
Old July 18th, 2006, 10:49 PM
The fan cycles on and off depending on the pressure in the system and the temperature of the engine. It definitely does not run all the time.
Old July 19th, 2006, 09:06 AM
artm
Arthur Maravelis
97 SW
In my 97 D90 the AC fan does NOT turn on immediately whenever the compressor engages. The manual says the compressor clutch engages between 35 and 435 psi at the trinary switch. The AC fan engages between 247 and 305 - a much smaller range. Also, fan engages at 225-deg coolant temp and AC turns off at 235-deg.
I'm pretty sure on my 93 LWB the fans engage always with the AC on. ???
I will say that those two RR fans sound very serious compared to the single, whimpy D90. A useful upgrade would be to replace the single with two high flow ones, and run them off the VW switch. These plus your VC fan should be nice.
Old July 19th, 2006, 09:29 AM
Monkeyboy
Guest
Posts: n/a
The fan on our '97 D90 does not run constantly when the a/c is switched on, but cycles.
Edit: Oh, the fan does run if the coolant gets hot regardless of the a/c function
The fan in the '94 Disco runs constantly when the a/c is on.
Go figure ...
KAA
Old July 19th, 2006, 09:46 AM
artm
Arthur Maravelis
97 SW
My plan is:
1. add a black box off the temp sender with a pot to select a temp to run the AC fan off of.
2. also feed the AC switch wire so that it comes on when the AC switch is on
3. add a new relay close to the fan
4. remove stock fan relay
This will give you added cooling with the AC fan(s) working directly off the temp sender.
By adding a new relay and the black box you can always disconnect that and reinstall the stock relay and you are back to stock setup.
fan
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
Possible sale of complete A/C Trigger For Sale - Parts 3 June 10th, 2005 02:36 AM
help with a/c motor Campbell Defender Technical Discussions 3 April 12th, 2005 12:25 PM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
