A/C compressor is whinning - Defender Source
Old April 1st, 2004, 10:27 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
My engine is making a whinning noise from the A/C compressor. I know this because I removed the belt in the fall and it solved the problem. I'm having a new belt put on today and would like to know what to suggest to the shop. They seem to think my compressor is on the way out. It seems to work fine though. Any ideas?
Old April 1st, 2004, 11:37 AM
If it work (blows cold air), then I would think it could be the pulley or the clutch slipping. If it doesn't work (AC blows warm air) I would say you are low on refrigerant.
Old April 1st, 2004, 11:52 AM
Campbell's Avatar
Campbell
Rich Campbell
It make the sound all the time when the belt is connected. Even when I'm not running the AC.
Old April 1st, 2004, 03:16 PM
There is a red wire on top of the compressor with a connector on it. Pull this connector apart. That wire controls the clutch, it should only get 12 Volts when you turn on the AC. My clutch would sometimes engage (get 12 Volts) after going through deep water and then it would whine. IF this is your problem I would trace the red wire back and find the relay as it needs to be replaced.
Old April 1st, 2004, 03:18 PM
cut the AC belt
Old April 1st, 2004, 03:21 PM
Campbell's Avatar
Campbell
Rich Campbell
I cut it last fall and the whinning was gone. I would like to have A/C for the summer so I want to put a new belt on. Mike....Do you happen to know what the relay part number is. If it is cheap enough I may just replace it. Also are you saying if I pull the red wire out of the compressor and the whinning stops it is the relay?
Old April 1st, 2004, 03:33 PM
THe relay is just a normal relay like the headlight relay, what happened to me was 2 things, one low on refrigerant which may have caused the whining, and 2 the relay started freaking out and engaging the clutch on the compressor causing it to come on and off sporadicly. The relay should only be $5 so it is cheap and easy to try. But like I said when you pull the red wire the noise should stop, you should also hear the clutch engage and disengage
Old April 1st, 2004, 03:59 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
With the belt off, turn the pulley. If it spins freely, then the clutch is disengaged. If it spins the compressor, then your clutch is frozen. Take a look at the belt--if the sides of the belt are cracked or if there is any loose threads, then the noise may have been just the belt. If the pulley spins freely, and the belt did not make a difference, then it most likely is just the pulley bearing. take off the pulley and just replace the bearing.
compressor
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
NAS 110 A/C questions rcork Defender Technical Discussions 13 July 19th, 2005 01:16 PM
A/C unit Ray Bone Defender Technical Discussions 2 June 7th, 2005 06:46 AM
Pulling out the A/C m.michaels Defender Technical Discussions 5 June 7th, 2004 12:01 PM
