A/C Compressor & 1994 D-90 3.9L - Defender Source
Old August 9th, 2015, 08:18 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Getting my all my ducks in a row in preparation for the engine swap and A/C install on my Right Hand Drive '86 D110, and the engine coming in, is out of a '94 NAS D90.
The issue is that the A/C kit I have came with the Denso compressor which has a serpentine belt, while the new engine has V belts.
I need help figuring out one of two things:
1) Can the Denso be made to fit the engine, and if so:
- what brackets do I need for it to mount on the block?
- can the serpentine pulley be replaced with a V pulley?
or
2) Should I consider changing everything over to a serpentine setup, and if so, what is required? Which brackets, pulleys, etc?
Name:	2015-08-09 12.25.51.jpg
ID:	126856   Click image for larger version
Name:	2015-08-09 12.26.01.jpg
Name:	2015-08-09 12.26.12.jpg
ID:	126858   Click image for larger version
Name:	2015-08-09 12.27.43.jpg
Name:	2015-08-09 12.27.52.jpg
ID:	126860   Click image for larger version
Name:	2015-08-09 12.28.11.jpg
Name:	2015-08-09 12.28.31.jpg
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old August 10th, 2015, 07:46 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
IAmKraig did a great deal of research around this. He had a 3.9 going in a 95 RRC with a Serp set up.
Old August 10th, 2015, 08:10 AM
Prolly easier to source the proper parts than redo the entire pulley drive. You need the AC bracket, a Sanden SD7 compressor with v belt drive, and the second tensioner pulley...
Old August 10th, 2015, 01:31 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I have the Sanden compressor that originally came with the engine, but the problem is that all the A/C hoses belong to the Denso. If you look close at the inlet & outlet in the picture, you'll see that they are not the same as on the Sanden.
The A/C kit I have must have belonged to an '97 D90 or '95 Classic. Both of those come with the Denso and a serpentine belt setup.
Thank you - Samer
2003 Discovery II
Old August 10th, 2015, 11:14 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
1of40: Thanks for the tip. I spoke to Kraig, and he convinced me rightly so, that the conversion to a serpentine setup is NOT the way to go.
There are too many things involved I the process that make it very difficult, and not worth the effort.
I've decided to use the Sanden compressor instead, and have new rubber hoses made up with the proper fittings.
Thank you - Samer
2003 Discovery II
1994, 90, ac, compressor, d-90
F&R ARB Air Lockers with 4.75 GBR R&P, Switches, Air Compressor, Air Line, Etc LRFlip For Sale - Parts 36 September 4th, 2014 12:35 AM
ARB CKMTP12 Compressor & Tank KKilo23 Defender Technical Discussions 10 April 20th, 2014 01:00 PM
ARB air lockers w compressor & switches RoverDude For Sale - Parts 3 May 26th, 2013 08:52 PM
Is the AC compressor on a 1994 style system the same as a 95 style system? evilfij Defender Technical Discussions 0 May 31st, 2010 06:20 PM
ARB compressor & outlets (?) Cube II Defender Technical Discussions 9 December 15th, 2004 03:48 PM
