A/C Clutch Control Switch - Defender Source
Old June 22nd, 2012, 03:53 PM
Mpfish82's Avatar
Mpfish82
'94 AA Yellow D-90 #690
Ok guys, I am hoping this isn't a new issue. I had the Clutch control switch go out on my A/C dryer that controls the high pressure and low pressure cut-off.
Is there any aftermarket fix for this? Rovers North said the piece is OEM and over 50% have been coming in with the wrong threading. When they won't sell you a part for $440 you know its bad. Anyways I was hoping someone here may have come across this issue and figured out how to fix it correctly!
Does anyone have one of these for sale on an old A/C system if no fixes are available?
Old June 23rd, 2012, 04:24 AM
What year truck?
Old June 23rd, 2012, 08:39 AM
Mpfish82's Avatar
Mpfish82
Old June 23rd, 2012, 06:52 PM
Get a new dryer and switch combo ... You'll probably have to change the electrical connector ... But these are just generic components.
clutch, switch
'97 NAS A/C Thermostat Switch BMGmotors Wanted 5 February 29th, 2012 10:25 AM
Ever replaced your front wiper control switch? chris snell Defender Technical Discussions 2 March 23rd, 2010 03:36 PM
removing clutch place from a/c compressor Campbell Defender Technical Discussions 2 May 1st, 2004 02:58 PM
