A/C busted on '97 SW - Defender Source
Old May 29th, 2010, 05:36 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
So, is there a quick list of where I should start with the A/C? Something like:
1. Charged?
2. Compressor working?
3. Trinary switch busted?
4. Receiver/drier?
5. Something else?
Help? And yes, I assume that I should have the system evacuated first. Thanks.
-Ren Ching
Old May 29th, 2010, 11:06 PM
See if the clutch on the compressor is working first. On discos and p38as they used to have to be shimmed with a washer. Then see if it has pressure in the system.
1997 SW side doors, top and rear door avail, and more from 97 LE wicks For Sale - Parts 21 April 28th, 2010 02:53 PM
97 D90 SW stuck in reverse. woldd90 Defender Technical Discussions 9 September 9th, 2009 09:56 AM
97 D-90 A/C lines Crash303 Wanted 0 June 8th, 2009 07:52 PM
Looking to swap 95 ST for 95 / 97 SW unit3a Wanted 0 November 28th, 2008 12:55 PM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
