A/C Blower motor - Defender Source
Old September 4th, 2014, 02:30 AM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
A/C Blower motor
Anyone know how to get this out? Its the blower motor for the dealer installed AC unit. I want to fix the mounts but can't get it out of my truck.
Old September 4th, 2014, 07:09 AM
the rover shop
shayne young
The two halves of the blower motor housing separate.. But you have to pull the ac unit out of the car to get to it..and there is no mounts persay.. What makes you think it needs the mounts changing..??
Old September 4th, 2014, 01:22 PM
petminded's Avatar
petminded
David
When you say that i need to pull the unit out of the car, are you saying the whole unit as in discharge and remove even the evaporator, or just the plastic parts?
The blower motor was only attached by two screws; one in each lower corner. Recently one corner has crumpled off and the motor is hung by only one screw. I got it wedged back up there, but I want to take the blower out, fit the plastic, and remount it in a secure fashion.
So is this a claim shell of sorts with the blower making up one half?
Old September 4th, 2014, 02:28 PM
the rover shop
shayne young
Yes.. Discharge and remove complete assy...that's the easiest way to make sure you don't break the housing etc and have to replace the whole unit.. Also that way you can test the unit by powering up the fan assy before you put it back in the vehicle..
Old September 4th, 2014, 02:43 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
Dude don't yank anything out!! I had the same thing happen to mine (whole blower was kicked off). I glued it back on with this stuff. Handles the vibrations like a champ!! Click image for larger version
Still going strong a year later.
Old September 4th, 2014, 03:40 PM
the rover shop
shayne young
I believe Hubba bubba works also.. Just gotta chew it for 10 minutes first... Cherry flavored works best..
Old September 4th, 2014, 04:01 PM
El Solis's Avatar
El Solis
Chris Solis
Grape man, it's all about grape or "purple flavor" depending on your geography.
Old September 4th, 2014, 04:20 PM
the rover shop
shayne young
Sorry, I like to get cherry when I can..
Old September 4th, 2014, 05:02 PM
El Solis's Avatar
El Solis
Chris Solis
not surprising really….
Old September 4th, 2014, 11:44 PM
petminded's Avatar
petminded
David
I didn't know they still made Hubba Bubba? If I can find any I'll try cherry as I don't like grape.
Old September 5th, 2014, 12:14 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
If you remember "Tidal Wave" bubble gum, with the liquid center, you'll have two part epoxy mixing as you chew! ;-)
blower motor for 110 nas Davis M Defender Technical Discussions 19 May 1st, 2008 03:49 PM
Blower motor tomaco1 Wanted 4 October 29th, 2007 11:46 AM
Need help with heater blower motor! Firefighter2904 Defender Technical Discussions 27 October 15th, 2007 09:51 AM
A/c blower motor Campbell Defender Technical Discussions 1 September 27th, 2004 08:19 AM
A/C blower motor Campbell Defender Technical Discussions 3 September 9th, 2004 11:01 AM
