A/C blower fell off - Defender Source
Old August 31st, 2013, 08:07 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
OK so the other day my buddy decides we didn't need A/C and kicked the blower on the bottom/back of the A/C unit in the passenger footwell. Looks like the plastic on the blower side cracked and/or broke off depending on the corner.
Any help in how I can reattach it? I can't reach it with any tools. I think I can just use self tapping screws to put it back together... How do I get to the back of the unit.
Old September 2nd, 2013, 11:48 AM
El Solis's Avatar
El Solis
Chris Solis
Bueller? Bueller?
OK there has to someone with at least an opinion on this.... I've tried looking but can't find anything that makes sense.
Old September 2nd, 2013, 12:07 PM
A good epoxy?
Originally Posted by pendy
I'm here for the D's
Old September 2nd, 2013, 01:35 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
The last one we fixed, we had to remove the whole blower from the case. Then, at each of the four corners, fabbed up some metal spacer pieces at each of the four corners, epoxied them in and reassembled. The plastic was far too weak to handle just running in screws with bigger flat washers on the one we fixed. Hope that helps!
Email is
Same place, new dogs.
Old September 2nd, 2013, 04:11 PM
El Solis's Avatar
El Solis
Chris Solis
Thanks everyone. Roverlab... How did you get to the 4 screws in the back to do all this? I think once it was out I could fix the broken plastic but how do you get to those screws?
'95/Wynn's A/C blower motor repair/replacement tgraham Defender Technical Discussions 12 June 3rd, 2016 03:40 PM
NAS 95 A/C blower budzny For Sale - Parts 7 November 22nd, 2014 08:46 AM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
A/c blower motor Campbell Defender Technical Discussions 1 September 27th, 2004 08:19 AM
A/C blower motor Campbell Defender Technical Discussions 3 September 9th, 2004 11:01 AM
