A/C aftermarket kit fitted, anyone has any idea on this? - Defender Source
Old May 12th, 2016, 05:45 AM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
Hi there. The Defender 110 i bought has an a/c kit installed after it was produced so it is an aftermarket kit and i believe was fitted in Italy. Has anyone any idea of the brand/seller/producer? I am trying to find installation manual so i can check wires for a fault i have with it.
Sent from my HTC_M910x using Tapatalk
Old May 12th, 2016, 09:16 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Probably a Diavia unit. They were dealer supplied kits at one time
Land Rover 110
Old May 12th, 2016, 11:16 PM
RBBailey
RBBailey
1965 IIa
I've seen one not unlike this that was also not the Land Rover version -- it was a GM kit.
Project:
1965 IIa SWB
Old May 13th, 2016, 12:54 AM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
Hi and thanks for the replies. Actually i am looking for the Istalation manual or any info that has the electrical connections for this.
Anyone can point me in somewhere?
Old May 13th, 2016, 12:09 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
What year is the truck? I have a diavia in my 94. The controls in mine are located in a little pod above the cigar lighter.
Jimmy Buffett
Old May 13th, 2016, 12:18 PM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
This is 98 year. The controls are located as you can see in the additional facia of the a/c
Old May 13th, 2016, 01:11 PM
I have installed a bunch of the kits from Elite who made the factory kit for the 95 up trucks. I have their instruction booklet but doubt that would be of much use to you. A/C is very simple, the thermostat has a probe that goes into the fins of the interior unit. That switches the compressor and front condensor fans on and off. The other switch simply controls the interior fan speed. There are usually two or three relays, some combine the condensor fan and compressor function into one relay. The kits are typically very simple with two heavy gauge switched power wires feeding these relays.
What is the problem you are having ?
Old May 13th, 2016, 01:22 PM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
Thank you Uncle Douglas for your repply.
Actually i am having two problems.
1. i can see and hear the thermostat (right side) works but the guys i bought the car from have wired the compresor directly from the on/off fan speed switch (left side) so compressor is on all the time.
2. The fan does not come on. Is off all the time.
Maybe there is to be checked for gas pressure/quantity and the pressure valve is to blame, don't know.
Because of this i was looking for installation booklet/manual. But the a/c blows cold at the moment but...
I am kind of lost.
Old May 13th, 2016, 01:29 PM
Winston-Rover's Avatar
Winston-Rover
Mike Giovannozzi
95 D-90 ST
it's a Diavia unit. I have the install manual but it's too large to post here. I can email it... or maybe someone on here can host the pdf.
Old May 13th, 2016, 01:32 PM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
Winston, thank you,
I was thinking the same, it is a Diavia kit.
The Elite is thicker at the air grilles than this? And is oem fitted to NAS and 50 anniversary models right?
Thank you again,
ac, kit
Anyone got Exmoor zip up door tops fitted? Michael110 Defender Technical Discussions 0 August 2nd, 2013 08:35 PM
Anyone ever fitted a Mercedes engine in a D90 ? grasshopper Defender Technical Discussions 21 January 27th, 2010 10:52 PM
Who has done an aftermarket cam? Bowtracer Defender Technical Discussions 7 June 25th, 2009 10:17 PM
Anyone Ever fitted a RH drive instrument cluster to a LH dash? LRNAD90 Defender Technical Discussions 3 September 23rd, 2008 03:22 PM
Has anyone tried any Penetrol SOUTHPAW26 Defender Technical Discussions 3 June 6th, 2008 10:51 PM
