a-arm joint/ wishbone joint - Defender Source
Old January 21st, 2007, 05:38 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
I am trying to put the a-arm back together on the D-90 and I'm running into a bit of a bind. That is, when I try to tighten the big nut that secures the a-arm ball joint to the rear axle, the ball shaft itself is turning and thus the nut will not go tighter. Is there an easier way to secure the ball while I tighten the nut on the bottom? Any help is appreciated!
I couldn't find much via a search, so if it's been discussed before, just let me know.
Thanks!
Old January 21st, 2007, 06:34 PM
cbass's Avatar
cbass
Bradlee Duncan
Thanks, I'll give it a shot with a c-clamp. I'm thinking I might have to go with the Rovertym a-arm adapter because of the lift. I've tried forcing the ball joint into the hole via other methods but none of them worked because it's binding quite a bit from the lift. Looks like I'll have to head off to Sears for a big c-clamp.
Thanks for the suggestion.
Old January 21st, 2007, 08:33 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You can also just slip a bottle jack over the ball joint and use the weight of the vehicle as leverage to hold it in place.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 21st, 2007, 09:07 PM
cbass's Avatar
cbass
Bradlee Duncan
Note sure if I follow on this one... do you mean put the bottle jack between the body (rear floor panel) and the top of the ball joint?
That's a great idea, but if that's what you meant, it won't quite work in my situation because the body is still off the frame :D
Old January 21st, 2007, 09:35 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Exactly, slip the jack between the ball joint and body and crank a couple of times to put pressure on the ball joint. It is, however, significantly harder if there is no body there.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Pittman arm removal? dameek Defender Technical Discussions 20 October 12th, 2009 07:17 AM
WTB: D-90 Cross rod end, steering drop arm, ball joint kit Blakesrover Wanted 1 October 1st, 2009 09:40 AM
Steering Arm Ball Joint Repair Kit ditskovich For Sale - Parts 0 August 30th, 2009 10:26 PM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
ball joint on the rear link/a arm rover4x4 Defender Technical Discussions 11 September 30th, 2007 08:09 PM
