A arm extension help - Defender Source
Old August 8th, 2013, 02:36 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
I've done the search and I can't find a definitive pic of how the RTE A arm extension is supposed to sit.
The shop I'm getting it installed at hasn't put one in before.
Does this look right?
I've seen pics with the notch toward the front and pics of the notch over the ball joint???
Help!
Old August 8th, 2013, 08:33 AM
If the holes aren't offset from each other than it shouldn't matter. Have you tried calling RTE?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old August 8th, 2013, 10:42 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
The holes are offset front the middle of the block.
Old August 8th, 2013, 10:54 AM
if the holes aren't offset from EACH OTHER than all you are doing is lowering the axle i.e it doesn't matter which way the block is oriented. Usually the lower pair of holes are set back from the upper pair in order to force the axle back. This, along with cranked radius arms and radius arm spacers serves to correct the pinion angle after a spring lift. Looking at RTE's website they state that the setback of the bolts is to the customer's specification i.e specific to their truck. So, is your part new or did you get it 2nd hand and just assume it was correct for your setup?
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
i'll see if i can get a pic of mine tonight
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old August 8th, 2013, 11:28 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Sorry, I wasn't clear.. The upper set ( there are four for two different positions - one for dc shaft and one for standard drive shafts) is offset from the lower set of holes. I did buy this used but I believe rte sells a "stock one" for their 3" lift or you can order a custom one...
Old August 8th, 2013, 11:55 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I just talked to my mechanic and he said it only fits the one way... If you try to flip it the a arm joint gets in the way... The picture must be deceptive because he told me that the pinion angle was tilted upwards pointing at the transfercase pinion as in should be with a dc driveshaft... Regardless of how the bolts line up, the drive line angle looks right in the pic or am I off my rocker?
Old August 8th, 2013, 01:14 PM
You own a Defender, you tell me...
Old August 8th, 2013, 01:16 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Lol.. Takes a certain breed :P
Old August 8th, 2013, 11:36 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Okay.. It's mounted and everything is correct right...NOT!!!
The damn thing hits the tank during compression... I know some of you run these... Did you have this issue and how did you solve it?
Old August 9th, 2013, 02:14 AM
About now is the moment we all wonder why we love these dang trucks.
Old August 9th, 2013, 11:34 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Bump... Lifted trucks out there? How did you avoid it hitting the tank?
Old August 9th, 2013, 12:10 PM
The Dro
Dro
1988 Ninety
Mark,
What is the "damn thing hits the tank"??
Do you have pictures?
Someone did a good write up in dweb
http://www.discoweb.org/aarm/index.htm
Not a D90. but you get the picture
Old August 10th, 2013, 01:06 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Originally Posted by The Dro View Post
Mark,
The damn thing hitting the tank is the a arm swivel ball...
I've seen that write up.. It's good but not helpful in my case because its a disco because
I talked to Bill at rte today... Really nice guy.. Had a lot of knowledge. I picked his brain for about an hour...
He says there is a common problem but only on D90s and the a arm block is different on them than on discos!
One of the few suspension components that are...
He gave me a suggestion to try out...
Mainly snug my rear arms right up (adjustable because they are the curry jointed ones) and use the set of holes on the a arm block that is normally used for std type driveshafts... Mine is dc...
I figure that snugging up the rear links will tilt the pinion way up and using the normal driveshaft holes will bring it down to somewhere a dc driveshaft will be happy in...
I think I'm just going to order the proper block and be done with it...
Anyone need an A-arm block for their disco?
Old August 10th, 2013, 01:54 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
How much lift are you running. You likely do not need an extension at all.
Old August 10th, 2013, 02:07 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
It about a 3" lift... I can fix the pinion issue with my rear links but the block adds to your travel by allowing your axle to droop that much farther before your a arm binds... (At least in my case )
Also using the block/rear links together to get your correct pinion allows the springs to sit relatively straight without using wedges (one offsets the other... Two slight adjustments vs one major)
Rovertym Rear A Arm Extension crown14 For Sale - Parts 5 December 12th, 2012 01:42 PM
Used Rovertym Rear A Arm Extension. j90hr For Sale - Parts 2 November 10th, 2009 08:58 AM
Pittman arm removal? dameek Defender Technical Discussions 20 October 12th, 2009 07:17 AM
Rovertym A arm extension mdmccallum Defender Technical Discussions 16 December 24th, 2007 11:20 AM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
