A-Arm Ball Joint Replacement - Defender Source
Old June 10th, 2004, 04:29 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I'm going to replace the ball joint in the rear A-Arm this weekend. I've heard various horror stories. Just wondering if anyone has any words of advice before I dive in. Thanks.
Old June 10th, 2004, 04:34 PM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
Spray it with penatrating lube and let it sit overnight. Oh and have a torch handy if it goes bad. Half of them are quick 30 min job, the others turn into major pains. A press helps to nock the balljoint in and out of the arm. Good luck.
Pete
Rigless for now
1999.5 CC PSD - Tow Bus
If it looks like it works and it feels like it works...Then it works
Old June 10th, 2004, 06:16 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I had to heat it with a torch then hit it with the BFH... Big Fuc$% Hammer. I pressed it back in. Not a big deal. Take the piece out and do it in a vice.
Legend in My Own Mind.
Old June 10th, 2004, 07:19 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Thanks for the info. I've got a local machine shop that says they can press the joint out/in, so I may take it there if I run into trouble (I don't have a torch available).
One other thing: Do you find it any easier to take this area apart by having the frame supported on stands or just leave everything on the ground? I'll be removing the trailing links as well so the axle will be connected to the frame only by the springs.
Old June 10th, 2004, 08:47 PM
redrover
Guest
Posts: n/a
Ryan, I would first get the threaded portion seperated from axle tube. I loosened the castle nut and shifted back in forth in driveway between rev/forward. If that doesnt loosen it, try jacking up the upper control arms a little and then pound upwards on the threaded portion of old ball joint. When you have the ball joint seat out of vehicle , you will need to cut the ends of the ball joint flange off. This is the 3/16 thick area surrounding the two screws that hold the ball joint to seat. Then bridge it over a open vise and pound it out. A 93 might be rust welded in there. I added a little anti seeze copper compound to new joint and pressed back in. Use 2 long bolts to act as guides when pressing in new ball joint. I also found a piece of pipe with a inside dia that fits cleanly around the balljoint boot to act as a press collar. I will include a drawing of the cuts needed on old ball joint flange. JP
Old June 11th, 2004, 11:32 AM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
JP - Thanks for the advice. Yeah, AFAIK it's the original ball joint so it may be stuck in their pretty good. I'm hoping this is one of those jobs that's not so bad once you actually do it. But it sounds like most people have to get a little aggro getting the old joint out.
ac
Steering Arm Ball Joint Repair Kit ditskovich For Sale - Parts 0 August 30th, 2009 10:26 PM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
Rear Ball Joint Buckon37s Wanted 4 April 9th, 2006 06:54 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
rear ball joint mattdh Defender Technical Discussions 3 October 13th, 2003 04:28 PM
