?????? - Defender Source
Old October 13th, 2005, 08:24 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Don't know what its called but its the piece in the transfer case which the speedo cable goes into.I am looking for the part # so i know what to ask for.
Thanks Jimmy
3rd low and BOOT IT
Old October 13th, 2005, 09:09 AM
scoloco's Avatar
scoloco
'94 D90 ST
Saw the following quote, any help?
"Simple job but be aware that there are a couple of different size outputs
(speedo gears) for the t-case.
When you get the inducer get the output that goes with it."
Old October 13th, 2005, 10:42 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
You mean an FRC3286 Housing-Spindle...as in the picture??? I have extras.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old October 13th, 2005, 10:50 AM
What Jimmy needs is the little plasic gear that spinns the lower speedo cable. He has one but the hole that the speedo cable goes into is too big. Apperently Euro defenders use a different speedo cable that has a bigger diameter center section and it isn't spinning Jimmy's cable. I belive he tried a new cable and it didn't help any. PS Rob, I have some more parts
Old October 13th, 2005, 11:06 AM
Roadsiderob
Robert Dassler
1994 D90
Ok, so he needs a speedo drive gear...what color?...how many teeth?...I've got bunches of this stuff.
Rob
Ok, how about this...I have a white 20 tooth gear and I have a new speedo cable to verify it fits the drive end. The parts fiche shows the euro trucks take a blue 20 tooth gear.
Mike, what parts you got?
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old October 13th, 2005, 11:29 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Rob,Thats the part i need,how much and to ship to MA 01844
Rob
3rd low and BOOT IT
Old October 13th, 2005, 11:30 AM
Hey Rob, I'll PM ya.
Old October 13th, 2005, 11:40 AM
Roadsiderob
Robert Dassler
1994 D90
Jimmy,
I'll trade you for the one that you have that doesn't work...I'll ship you mine and you ship me yours. First class in a padded envelope should cost about $1.00. PM me your complete address.
Rob
Jimmy,
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old October 13th, 2005, 11:54 AM
D110XD's Avatar
D110XD
Michael-P. Richter
110 HT XD 1997
...for future part-research.... try this one. I like it. you can find almost everything here...
http://www.landy-depot.com/cgi-bin/W...age_query.html
mike
The important field is the 3rd.
"Freie Suchworte". For example "spedo:
13H9205L RESET CABLE FOR SPEEDOMETER SERIES 3. 13.36
211502 OIL SEAL SPEEDOMETER PINION (GEN. LAND ROVER) 1.39
217620 SHIM FOR SPEEDOMETER DRIVE .015" ( OBSOLETE / NLA WHEN OUT OF STOCK) 1.09
217622 SHIM FOR SPEEDOMETER DRIVE .005" ( OBSOLETE / NLA WHEN OUT OF STOCK) 0.89
217623 SHIM FOR SPEEDOMETER DRIVE .010" ( OBSOLETE / NLA WHEN OUT OF STOCK) 1.74
231911 SPEEDOMETER 1948-53.EXCHANGE. 230.53
232565 PLATE RETAINING PINION SPEEDOMETER DRIVE 1950-84. 14.24
232566 RETAINING PLATE SPEEDO CABLE. 6.21
232846 DOWEL IN SPEEDO HOUSING SERIES 3 ( OBSOLETE / NLA WHEN OUT OF STOCK) 2.95
233243 GROMMET SIDE LAMP LEAD SERIES 1 1954-58 AND SPEEDO CABLE 2/2A 1.69
235455 SHIM FOR SPEEDO DRIVE .003". ( OBSOLETE / NLA WHEN OUT OF STOCK) 0.46
239564 SPEEDOMETER S.W.B 1954-66. 106.21
239565 SPEEDO SER 2A 163.12
239600 CLIP FOR SPEEDO CABLE & VARIOUS APPLICATIONS. 1.55
240407 CLIP FOR SPEEDOMETER CABLE. + DISCOVERY ACCELERATOR CABLE PETROL V8 0.93
267782 GASKET FOR SPEEDO DRIVE 1950 TO 1984 ( OBSOLETE / NLA WHEN OUT OF STOCK) 0.13
268791 SLEEVE FOR SPEEDOMETER PINION. ( OBSOLETE / NLA WHEN OUT OF STOCK) 15.80
268883 CLIP SPEEDO CABLE AT CAMSHAFT COVER ( OBSOLETE / NLA WHEN OUT OF STOCK) 1.48
273370 GROMMET FUEL PIPES 109 V8 + RANGE ROVER, 90/110 & 2 LITRE DIESEL AND SPEEDOCABLE 2A 0.74
278010 CLIP FOR SPEEDO CABLE DIFF PIPE ON INLET MANIFOLD RANGE ROVER <1985. 0.97
279341 SPEEDOMETER ( OBSOLETE / NLA WHEN OUT OF STOCK) 210.25
508044 SPEEDO CBL 2B F/CONT ( OBSOLETE / NLA WHEN OUT OF STOCK) 47.13
528747 OIL SEAL FOR SPEEDOMETER PINION 4 SPEED V8 (GEN. LAND ROVER) 4.52
533765 RETAINING PLATE FOR SPEEDO CABLE V8 4 SPEED (GEN. LAND ROVER) 3.41
540115 SPEEDOMETER ( OBSOLETE / NLA WHEN OUT OF STOCK) 191.32
540129 SPEEDO 2A 88 123.85
540134 SPEEDO KPH TRIP *OBSOLETE WHEN OUT OF STOCK* 192.15
559159 SPEEDO S2A 6CYL MPH 164.33
559165 SPEEDOMETER 118.33
571940 GASKET SPEEDO HOUSING V8. 4 SPEED GEARBOX (OEM) 1.29
579165 SPEEDO CABLE (OEM) 14.22
579166 SPEEDO CABLE LHD RR (R) 13.40
589273 SPEEDO CBLE ( OBSOLETE / NLA WHEN OUT OF STOCK) 21.69
623055 SPEEDOMETER CABLE L.H.D SERIES 3 6-CYL (R) 9.65
6860L RUBBER BUSH FOR BRAKE PIPE REAR SERIES 1,1948-58 & DISCOVERY & SPEEDO CABLE SERI & 101 (R) 0.24
78924 SCREW FIXING SPEEDO DRIVE (GEN. LAND ROVER) 0.34
90576631 HSG.SPEEDO DRIVE R/R4S ( OBSOLETE / NLA WHEN OUT OF STOCK) 177.19
90623054 SPEEDOMETER CABLE SERIES 3. (R) 12.64
AAU2304 OIL SEAL SPEEDO HOUSING RANGE ROVER, 90-110 & DISCOVERY. (R) 1.37
FRC1536 PINION DRIVE SPEEDO 1954-84. (R) 15.61
FRC2283 SPEEDOMETER- ( OBSOLETE / NLA WHEN OUT OF STOCK) 80.97
FRC3286 SPEEDO HOUSING,4 CYL LT77S & LT85.LAND ROVER 90/110,DISCOVERY & RANGE ROVER > 1985 (OEM) 15.29
FRC3310 SPEEDOMETER DRIVE GEAR 90/110 BLUE (OEM) 7.96
FRC3313 GEAR SPEEDOMETER (GEN. LAND ROVER) 20.85
FRC5409 GASKET SPEEDO HOUSING 90-110.& DISCOVERY (R) 1.07
FRC6152 SPEEDO HSNG ( OBSOLETE / NLA WHEN OUT OF STOCK) 90.56
PRC1061 SPEEDOMETER ( OBSOLETE / NLA WHEN OUT OF STOCK) 362.15
PRC2607 SPEEDOMETER K.P.H. WITH TRIP 109 SERIES 3. (OEM) 147.00
PRC3717 SPEEDO CABLE UPPER TWO PIECE SERIES 3. (OEM/ISO9002) 4.44
PRC3722 SPEEDO CBL V8 S3 LHD ( OBSOLETE / NLA WHEN OUT OF STOCK) 17.53
PRC3965 SPEEDO CABLE (OEM/ISO9002) 19.29
PRC4347 SPEEDOMETER KPH (OEM/ISO9002) 191.40
PRC4348 SPEEDOMETER MPH (OEM/ISO9002) 191.40
PRC4484 SPEEDO CABLE END ( OBSOLETE / NLA WHEN OUT OF STOCK) 26.80
PRC5564 SPEEDO CABLE RHD (R) 12.68
PRC5565 SPEEDO CABLE LHD (R) 13.40
PRC5567 SPEEDO CABLE UPPER 90-110. (OEM) 6.61
PRC5567/63 SPEEDO CABLE 17.14
PRC5568 SPEEDO CABLE (R) 8.54
PRC5662 SPEEDO CABLE (R) 11.18
PRC5663 SPEEDO CABLE LOWER.90/110 4 CYL. RHD (R) 10.87
PRC5664 SPEEDO CABLE LOWER 90-110 V8 UPTO 1987 (R) 12.83
PRC6017 SPEEDOMETER CABLE 1 PIECE RANGE ROVER 1986 ONWARDS RHD (R) 14.95
PRC6018 SPEEDO CABLE LHD (GEN. LAND ROVER) 58.19
PRC6021 SPEEDO CABLE LHD (R) 15.65
PRC6022 CABLE SPEEDOMETER 90/110 4 CYLINDER RHD (R) 11.91
PRC6023 SPEEDOMETER CABLE 1 PIECE TYPE 90/110 V8 RHD FROM VIN. NO. 268017 (OEM/ISO9002) 13.10
PRC6278 SPEEDO CABLE (OEM) 23.73
PRC6279 SPEEDOMETER 62.77
PRC7373 SPEEDOMETER M.P.H. 90/110. (OEM/ISO9002) 209.61
PRC7374 SPEEDOMETER 90/110 KILOMETERS 140 KPH (OEM) 199.00
PRC7949 SPEEDO CABLE (R) 9.52
PRC9872 SPEEDOMETER CABLE DISCOVERY RHD TO LA081991 V8 CARB AND TDI (R) 15.18
PRC9873 SPEEDO CABLE (R) 17.57
RTC3484 SPEEDOMETER CABLE 1950-71. (OEM/ISO9002) 14.36
RTC6598 SPEEDOMETER (GEN. LAND ROVER)
