9mm x 1.25 x 30mm grade 8 bolts - Defender Source
Old June 29th, 2009, 12:16 AM
cdb
Clark Bowen
I need the above bolts for the ring gear and I cannot locate them anywhere. They are for Ashcroft 4:10 R & Ps and I'd prefer to have a USA source for speed and availabilty.
Anyone know who might have them?
Old June 29th, 2009, 02:04 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Did you try McMaster Carr?
Old June 29th, 2009, 08:13 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
try Metric Multi Standard http://www.metricmcc.com/
Old June 29th, 2009, 11:26 PM
cdb
Clark Bowen
Thanks...
I checked them all including Ashcroft and Randy's R & P. Nobody has the %$#% things. It doesn't appear as though Ashcroft made this R & P so now I'm trying Kam in the UK.
A friend may be able to make them on a CNC machine after he writes the program, however.
Old July 2nd, 2009, 11:31 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Are you sure they are 9mm x1.25? That is a very wierd size. Maybe 3/8-20....which I think is a B.S. size, which would make much more sense. IMHO making bolts with a lathe or CNC machine may be a bad idea as they won't be hardened and cut threads are not as strong as rolled threads.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old July 2nd, 2009, 11:39 PM
cdb
Clark Bowen
Hello Rob.....
Yes, they have been measured by both the mechanic and the local bolt/nuts supply house.
Evidently, Ashcroft used this size at one time but discontinued them according to George at RDS. Ashcroft says they only used 10mm and 3/8ths unp.
I'm stumped and a bit frustrated. Can't tap the R & P - flame hardened and can't get the bolts.
Emailed Kam Diffs too but have not heard back from them.
I appreciate your comments on cut bolts - I didn't know that.
What else would you do?
Clark
Old July 3rd, 2009, 12:53 AM
Roadsiderob
Robert Dassler
1994 D90
Here's a neat web site...http://www.britishfasteners.com/threads/bsf.html
I'll see if I can find 9mm
Clark, man, you always have the wierdest shit go wrong... I searched all around and the only reference I came across was that Alpha Romeos use 9mm driveshaft bolts. You might try searching some Alpha forums or specialty companies. I, personally, would buy a R&P set from GBR that I could actually get bolts to fit. That would be the simplest, most direct fix.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old July 3rd, 2009, 01:30 AM
ARP should be able to make them if they don't have them. My 3 liter head bolts were 11mm... Can't find that size anywhere...
Just phone em up...tell them what you need.
http://www.arp-bolts.com/index.html
Old July 4th, 2009, 06:26 PM
cdb
Clark Bowen
Turns out that they aren't 9mm x 1.25 x 30mm. They are 3/8ths BSF (or 3/8ths x 20 x 1 1/4). Makes more sense and they are nearly identical.
With the help of Roadside Rob and Bill Davis we finally figured it out and I decided to take their advice and get a new R & P (4:14 from GBR).
Thanks for everyone's help.
Old July 4th, 2009, 11:02 PM
Roadsiderob
Robert Dassler
1994 D90
Glad you got it worked out.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old October 27th, 2012, 11:33 AM
rosshimebauch
Ross Himebauch
none
9mm x 1.25 taps and dies can be bought at MSC Industrial. They have an online catalog (MSCdirect.com)
Old October 27th, 2012, 01:11 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
That's the same size as the two threaded holes on the bottom of the diff that QT gaurds bolt onto.
bolts
starter bolts jstrong98 Defender Technical Discussions 0 November 1st, 2005 11:14 AM
Source for long body bolts? 1/2x7.5 inch grade 8 cgalpin Defender Technical Discussions 7 March 12th, 2005 12:59 AM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
