97'Nas Stalls out and dies - Page 2 - Defender Source
Old March 25th, 2006, 09:58 PM
Antonios
Antonios Hadjigeorgalis
No more
I had a real similar problem with my 94. Try unplugging the Vehicle Speed Sensor and see if the trucks behavior changes. Mine started off only stalling right after I started up cold, but then progressed to when hot, and finally to the point where it would drive fine in the morning, but I could barely make it home it drove so bad in the afternoon.
I unplugged the sensor and it drove 100% better, although it still occasionally stalled or idled rough. Apparently no signal is better than the bad signal that thing puts out. I just replaced it today and the truck is driving perfect.
Miami, FL
Old March 26th, 2006, 02:21 AM
Cholla
Jack Copass
97 D-90 SW
Hello Antonio, I thought that this might be a factor also, and replaced my VSS last month, but no change... I was surprised that this sensor fell apart upon removal from the transfer case, yet the speedometer was still working OK. I discovered today, upon capturing some data with my code scanner while idle was dropping below normal and about to stall, that below 650 rpm, the fuel system #1 and #2 are going into "open loop", which I think means O2 sensors are not providing signal, and ECU goes to default mode which may be a factor. I have got to do some more testing... Thanks for your input,
Jack
Old March 26th, 2006, 11:33 AM
Chaucer
Will
93 110 | 97 90
Hey Jack,
I had the same symptoms you describe to a T. My problem was two-fold: The Crankshaft Position Sensor was shorting out. I saw a nice dried-up, crusty stubstance all over it that I thought was probably antifreeze. I was right, but I needed to figure out where the leak was coming from. I bought some ultraviolet dye from Schucks or Napa and put it into the radiator. I let the problem run for a while a week or so, maybe less. I then took the UV flashlight and looked for the florescent predator-blood trail. It definitely was coolant that was shorting the Crankshaft Position Sensor. I started looking around the block and found the leak was coming from the head gaskets.
So basically my head gaskets were leaking and dripping coolant onto the CPS, shorting it out...causing the symptoms you are seeing.
Give it a looksee...
Old March 26th, 2006, 01:30 PM
Cholla
Jack Copass
97 D-90 SW
Originally Posted by Chaucer
Hey Jack,
Hello Will, Thanks much for your input. I will check that out. Is that sensor difficult to take out and inspect?
My 97 has 70K on the clock now. Thanks,
Jack
Old March 27th, 2006, 12:18 AM
Chaucer
Will
93 110 | 97 90
Hmm. Don't remember, I switched it out with a new one which ran around $50.00 or so. 70K? I was around that mile range also when it happened to me.
Old March 27th, 2006, 12:25 PM
Cholla
Jack Copass
97 D-90 SW
Thanks for your input, Will, I will check that out today.
Jack
Old March 31st, 2006, 08:58 PM
Cholla
Jack Copass
97 D-90 SW
Stalling 97/ intermittent low idle
Hey Jack,
Hi all, well, I pulled out the crankshaft position sensor and found it looking OK, with no residue of any kind on it, but installed a new one for good measure (hoping maybe my original sensor was the source of problem). After that, it started and ran normal for about 10 miles, but after stopping for a few minutes, it would start but would not idle at all. Same thing about 10 times, until I step on the gas a little to rev it up. After a few minutes driving, then it reverts to normal. I read that sometimes the stepper motor piston will not hold position, creeping forward, after engine is shut off, instead of staying fully open for restart. LR techs removed the spring behind the stepper motor piston, to correct starting/immediate stalling probem. Don't know if this is my problem, but I will give it a try.
Otherwise, getting down to replacing ECU, engine harness or, ???? I thought maybe the evap canister purge valve might be sticking, but after removing/plugging vacuum tube that goes to that from the plenum, and driving, problem still persists. When this problem occurs, my scanner shows low idle, (if it doesn't stall) and the fuel systems 1 and 2 are in "open loop". No fault codes or pending.
97, nas
