97D90 Purge Valve Replacement - Defender Source
Old October 19th, 2012, 01:05 PM
ESB
Erik Brynildsen
97/D90
Two Questions:
1. Can you replace the purge valve on a 97/D90 with the a Mitsubishi purge valve like some other rovers and defenders?
2. Also is this a pretty easy fix?
Thanks for any input
90, 97, ac, d90
Purge Valve The Wizard Defender Technical Discussions 5 September 24th, 2014 05:43 PM
Code P1179 Purge Valve ? ERICZZ Defender Technical Discussions 3 September 22nd, 2009 04:20 PM
Need Purge Valve for Air Filter Box taoseno Wanted 0 September 10th, 2009 02:27 PM
Valve Cover Gasket and Tierod replacement bjf Defender Technical Discussions 3 February 10th, 2009 02:02 PM
Purge Valve ESR4222 Hammertime Wanted 0 February 6th, 2009 03:48 PM
