97 will not Idle - Defender Source
Old September 15th, 2009, 10:34 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
97 will not Idle
I can get it started and keep the RPM around 900 with the help of the gas pedal. But will not idle.
Thanks in advance.
--Benjamin Franklin
Old September 15th, 2009, 10:36 AM
clean stepper motor.
Old September 15th, 2009, 02:55 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
To piggy back on this subject..
1. Where is the stepper motor?
2. Would this also correct an idling problem once the engine is warm? I have an intermittent problem with idle after I have driven a short distance, park it for 10-15 minutes, and try to leave. It starts right up but struggles to idle until I rev it up enough to get moving then it drives just fine. It is on a 97 as well.
Old September 15th, 2009, 03:02 PM
Does the 97 have a stepper motor?
Old September 15th, 2009, 06:00 PM
GYM's Avatar
GYM
Gary
97 SW
Yes, but I think the '97 (GEMS) is different than the 94/95.
Old September 15th, 2009, 09:03 PM
Jase
Jase
pending
Had the same issue at one time. Cleaning the stepper thoroughly corrected the issue.
Stepper is on the driver side of the intake (front facing side), over the valve cover, just pass where the rubber air intake hose connects. If I remember correctlly its the only sensor in the area.
Old September 15th, 2009, 09:31 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Not Idling
I had a similar issue but found the one of the PCV hoses had a hole in it. Check that also.
Old September 26th, 2009, 01:33 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Cleaned stepper motor, wasn't that bad, runs great now.
Thanks All
--Benjamin Franklin
97, idle
High Idle on 97 D90 ndhlp Defender Technical Discussions 3 November 26th, 2006 11:59 AM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
fluctuating idle KeithElisa Defender Technical Discussions 15 May 31st, 2006 08:38 AM
High Idle tron Defender Technical Discussions 5 February 15th, 2006 03:33 PM
