97 throwing P1178 code and tickig from behind the dash - Defender Source
Old April 20th, 2015, 01:31 AM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
So I'm having issues with my 97 NAS. It started a couples weeks ago, a day or two after offroading in wet and muddy conditions. It started with a ticking noise started behind the dash like I have my hazard lights on. The noise is on all time regardless of the ignition on or off. Also the check engine light came on with P1178 code. The truck started running very rough at idle, but ran okay speed. With the live feed from the code scanner I noticed the MAF sensor was not giving any feed.
So far I took a part the dash and found that the ticking is coming from the relay in the little green box behind speedo or 10AS immobilization module. I remove fuse 3 from the main fuse box in the engine compartment, which stop the ticking. Although now and then the truck will immobilize and will not start, but with a quick switch on the battery disconnect I can start the truck again. I have replaced the battery and the Mass Airflow sensor. I have checked and cleaned the main grounds throughout truck. I checked to see if the MAF connector had voltage and good ground. But I left it disconnected and the truck seems to be running okay and has not thrown a code yet.
If anyone has any other ideas it would be much appreciated.
When the F*%# did we get Ice cream!!!
"They are, in factory original condition, noisy, they leak water in from the top and oil out from underneath, you can never demist the windows in winter, they handle like scaffolding towers, and use more fuel than Beijing." Richard Hammond
Old April 20th, 2015, 07:17 AM
Lemonhead
TB
1997 D90 SW
I have that same ticking noise/green box issue but mine comes and goes every couple months - usually just turn the truck off and back on again and it stops - it does not stop if I just turn the truck off. Past searches on this site offered no fix and since it always stops with that trick - I haven't bothered to research further.
Would love to know as well what the permanent fix for it is.
No codes thrown BTW when it clicks.
Old April 20th, 2015, 07:41 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
This is somewhat of a long shot but a shop in Bethesda Md called Independent Land Rover specialists seem to have dealt with some odd issues re customer 97NAS trucks. Might give them a call and ask for Dean. Nice guy and busy as hell but will stop to help if/when he can.
Clay
97, dash, wing
WTT: Tuffy and throwing in kevincdoyle Wanted 11 March 5th, 2014 02:10 PM
Code p1178 Campbell Defender Technical Discussions 4 September 15th, 2012 10:42 PM
Running rich without throwing codes vesparover Defender Technical Discussions 8 January 20th, 2009 04:05 PM
Code P1178 NashvilleRedD90 Defender Technical Discussions 1 July 2nd, 2007 12:56 PM
Throwing up - flu or the new Jeep Defender paulb Misc. Chit-Chat 15 October 22nd, 2006 11:12 PM
