97 T-case shifter - Defender Source
Old November 25th, 2003, 09:28 AM
ronward's Avatar
ronward
Redsrover
None - sadly
97 T-case shifter
Has anyone fitted a longer shift handle to their 97 transfer case? The Automatics come with a center console unit. Mine is factory, and the t-case shift lever is pretty short. I'd like to ditch the leather shift boot and make the shifter about an inch longer. I suppose an aftermarket shift knob might fit but I want to avoid the bling bling look. Any thoughts?
Old November 25th, 2003, 04:12 PM
If you wanted the easy way out you could use a turn-buckle nut and a piece of threaded rod.
97 D90 Transmission Shifter Tear Jon_Winningham Defender Technical Discussions 11 November 6th, 2009 02:36 PM
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Borg Warner Transfer Case Shifter Linkage (RRC) cellulararrest Wanted 2 August 22nd, 2007 01:20 PM
Need 97 auto trans shifter light unit thingy wicks Wanted 2 December 22nd, 2004 12:59 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
