97 SW rear door electical problems! - Defender Source
Old September 4th, 2007, 06:24 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
I am having troubles find out why nothing on the rear door works. I have pulled all the relays and tested them, they alll checked out O.K. Squiter (washer) does not work, wipers and rear heater. All the fuses seem O.K. Is there something I am missing? I also hace the Factory Servicemanual Data (RAVE) on CD. I am having conflicting issues with what the say the relay should be 4 vs 5 pole relays. It will point out a yellow relay and say it is a 5 pole and all mine are 4 pole the Green ones are all 5 poles. It will also call for a 5 pole to be put in a socket that you can tell only has 4 female terminals in the socket, What is up with that? Does each relay operate more than one circui?
the order of relays from left to right tell me if this is correct.
Yellow Yellow Empty Yellow Green Green Green Yellow
4 pole 4 pole 5 pole 4 pole 5 pole 5 pole 5 pole 4 pole
Old September 4th, 2007, 08:51 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
One thing to consider - computer requires all the doors to be closed. So if they are physically open, close them. You may also want to check your door interlocks. HTH. Mark
97, door, problems, rear door
1997 SW side doors, top and rear door avail, and more from 97 LE wicks For Sale - Parts 21 April 28th, 2010 02:53 PM
Rust free rear door for a 97 SW Campbell Wanted 2 April 10th, 2009 05:02 PM
WTB Rear Speaker Housing for 97 D-90 SW wadaman Wanted 0 March 5th, 2009 08:44 AM
97 SW Rear Hoop Pix Yousef dnewman9 Defender Technical Discussions 4 July 20th, 2004 01:55 PM
