97 Starting problem - Defender Source
Old May 18th, 2011, 01:03 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
97 Starting problem
Just wondering if this has happened to anyone else.
My 90 has trouble starting. It cranks but doesn't start all the time. more so when hot. New fuel pump has been installed. Also the front condensor fan isn't coming on. Bypassed the ecm and it came on so my mechanic thought it was the ECM.... but put a another ECM from a 96 Disco and the same problem is happening.
Any ideas?
Old May 18th, 2011, 01:41 PM
How about the coolant temp sensor? Does it start when you put your foot on the gas while cranking? Does it sputter and try to start? Do you smell raw fuel while/after cranking?
Ron
PS I will give you 12k for her as she sits.
97, start, starting
Starting problem (occassionally) kolvedic Defender Technical Discussions 21 January 21st, 2012 11:12 AM
Intermittent Starting Problem 61rover Defender Technical Discussions 0 September 24th, 2010 01:50 PM
Hot starting problem that won't go away. lostindecoland Defender Technical Discussions 8 February 27th, 2010 10:53 PM
Help! Problem starting (95 SW) reaper99999 Defender Technical Discussions 8 March 2nd, 2006 07:22 PM
Odometer problem 97 jorge Defender Technical Discussions 3 November 19th, 2003 01:13 AM
