97 ST coolant leak when running - Defender Source
Old May 20th, 2015, 06:34 PM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Folks,
My 97 just started leaking coolant while running. It appears to becoming from the housing where the fans belt attaches. Is this common. Any way to check? Thanks
Old May 20th, 2015, 06:40 PM
Originally Posted by nflory View Post
Folks, My 97 just started leaking coolant while running. It appears to becoming from the housing where the fans belt attaches. Is this common. Any way to check? Thanks
Water pump probably.
Old May 20th, 2015, 10:53 PM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
I loosened the radiator cap and plugged the overflow to see if I was getting blowback through the system (head gasket). Doesn't appear to be. Looks like the leak is coming off the top of the inflow on the pump from the radiator. The hoses look a little tough. Not sure what my next move should be.
How hard is it to change out the water pump? Any idea on total labor?
Thanks again
Nate
ID:	121286   Click image for larger version
Old May 20th, 2015, 10:54 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Easy job for DIY. Download the rave, orders the parts. Get a new thermostat as well. New gasket and new new pump.
Old May 20th, 2015, 11:01 PM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Thanks Roverdoc. Anything else I should look for before ordering the pump, thermostat and gasket? If I take off the belt the water pump pulley should have some play in it if shot correct? Any guidance is greatly appreciated. Thank you.
Old May 20th, 2015, 11:22 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Well. Depending on service history, may be a good time to replace the viscous clutch that attaches to the pump and the fan. I like to think of the clutch, pump, gaskets, thermostat all in one job since you are there. If removing the fan, purchase the correct wrench. I have a park tool bicycle spanner wrench that works perfect.
Old May 21st, 2015, 12:39 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
There is a weep hole under the pulley on the face of the pump that is designed to leak when pump is shot. If it was me, I'd remove the radiator to change the pump and do the step belt, have the radiator flushed (unless recently done). Not sure if I'd change the t-stat or clutch unless there was issue-- but if money is no object, then sure.
Old May 21st, 2015, 01:00 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Slippery slope. I would say if you have the radiator out then you may as well pull the motor and do a galvanized chassis as well.
Joking aside. I am currently deep into a refresh and the more I take apart the more I want to do. Ship fitters syndrome.
97, coolant
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
coolant leak jperakis Defender Technical Discussions 2 February 27th, 2005 02:39 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
