'97 NAS turns over then stalls - Defender Source
Old January 24th, 2016, 04:48 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
In the middle of the snow - sometimes turning the key will get the starter going, sometimes not.. when it does turn over, it holds the idle for 1-4 seconds, then dies. Fuel pump seems to be working (can hear it). Any ideas? Yes, I searched the forum and found very little that was 97 specific. Thanks.
Edit: sometimes power doesn't even go on when I turn the key, which might be another problem altogether. Blah.
-Ren Ching
Old January 24th, 2016, 04:52 PM
phoenix37's Avatar
phoenix37
john
its happened to me with my 95 LWB...some dry gas cleared it up... maybe clogged fuel filter or a pump on its last leg.
Old January 24th, 2016, 04:56 PM
smob's Avatar
smob
Steve
Hmm.. Good idea. Pump was replaced recently but not filter. I'll try to get some new gas in it.
-Ren Ching
Old January 24th, 2016, 05:06 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Mine's a '94 but same symptoms and it was an ignition switch.
Good luck,
Jay
Old January 24th, 2016, 07:32 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Originally Posted by genie90 View Post
Mine's a '94 but same symptoms and it was an ignition switch. Good luck, Jay
Second this...
------ Follow up post added January 25th, 2016 12:33 AM ------
Originally Posted by kevincdoyle View Post
Second this...
Very easy, inexpensive fix...prolly needs to be done anyway...
Attributed to Shayne...
Old January 24th, 2016, 07:45 PM
smob's Avatar
smob
Steve
Got one on order from Trevor.. I have this odd feeling that when I left the truck idling for an hour in the snow, the heat (which is busted) heated up inside the dash and caused the burning that I smelled.. guessing that was from the ignition switch melting. I'll swap this in later in the week and whine again if it didn't work.
-Ren Ching
97, nas
1986 17H Turns Over But Won't Start willhahn24 Defender Technical Discussions 0 September 13th, 2014 11:14 AM
300TDI stalls, then cable restarted in a minute Earlclue Defender Technical Discussions 0 December 6th, 2013 05:47 PM
RPMs die, then vehicle stalls at next light. sro Defender Technical Discussions 19 November 22nd, 2012 09:23 PM
Engine turns over when shutting off usadventureracing Defender Technical Discussions 4 June 24th, 2012 10:49 AM
Engine turns over but won't start bd90 Defender Technical Discussions 9 August 8th, 2008 12:22 PM
