97 NAS SW Rear Door Light Trigger - Defender Source
Old January 2nd, 2012, 06:37 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
Hi all,
Happy New Years! Quick question... on the 97 SW... does opening the rear door turn on the interior lights? Sounds stupid as there is a trigger there but mine doesn't turn on any lights. There is no power going to that trigger. Examining the wiring diagram... there is no "rear door" switch. I just wanted to confirm it indeed is supposed to turn on the light before chasing wires.
Thanks.
aaron
Old January 2nd, 2012, 06:44 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
Past: '97 D90 LE #135
Yes, it should. Mine does anyway. One thing you could try is sliding the toggle on the overhead dome light. There may be a setting to cutoff the lights turning on when the door is opened.
Current Stable:
2016 BMW M3 (Mineral Grey)
2013 Ford Raptor (Tuxedo Black)
Previous Rovers:
1997 LR D90 LE - #135
1997 LR D90 ST - #1185 (BRG)
2000 LR Discovery SII (Oxford Blue)
2008 LR LR3 HSE (Alaska White)
2012 LR LR4 Lux (Fuji White)
Old January 2nd, 2012, 06:47 PM
Verner Berry's Avatar
Verner Berry
Verner Berry
97 D90
Correct, opening the door triggers the switch to turn on the dom light, sometimes corrosion can get in there and keep it from engaging I would unscrew it, clean and reinstall it see if that helps. If not the switch is a few bucks new.
Old January 2nd, 2012, 06:55 PM
esprit99's Avatar
esprit99
Keith Imbriglio
1997 D90 SW Arles Blue
The trigger does turn on the rear light only. There is no power going to the door pin. The door pin sends a ground to the dome light when the door is open. The power wire goes directly to the dome light. Most times the door pin goes bad. Take the door pin out, one screw, and ground the wire going to the door pin. If the light turns on you have a bad switch. If not make sure the bulb is good. If the bulb is good then I would take the light out and make sure the light has power.
Life is to short to drive ugly cars
'97 D90 SW #2251 Arles blue
'16 RRE
'04 Disco
Old January 2nd, 2012, 07:25 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I understand both interior lights come on if the light switches are set the same. There's also a "brain" that will turn them off if you leave the door open for an extended period of time. BMW made lots of electrical changes to the 1997 vs's earlier model years.
Old January 2nd, 2012, 07:43 PM
aaronlam's Avatar
aaronlam
aaron lam
Thanks... yes... the rear dome light works and has power... the front doors turn on that rear light (as well as the front light). Maybe that's not right.
I grounded that wire and still nothing. Any idea where that wire goes? I chased it under the car but looks like it goes into the frame. I have to redo my headliner so wondering if I can just bypass all that and connect directly to the dome light somewhere. Maybe the PO had it changed so that the front doors turn on both lights and the rear does nothing.
Old January 2nd, 2012, 08:10 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Pup, On a 1997 SW, it's proper that BOTH lights go on when any of the 3 doors are open... don't make me say it again !!
The switches provide the ground point for the lights.
Old January 2nd, 2012, 08:13 PM
bjf's Avatar
bjf
barry f
94 ST #395
Brain you sure?
Old January 2nd, 2012, 08:21 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Originally Posted by bjf View Post
Brain you sure?
Yup, I have all the original electrical guides for the '97. It's a small box behind the center thing that has the wiper control switches on it. Within the "brain" is also the sounder for "you left the lights on dummy" and "your door is ajar, dummy" and that nice little chime that tells you to buckle up before I report you to the cops.
Old January 2nd, 2012, 08:49 PM
bjf's Avatar
bjf
barry f
94 ST #395
Learn something new every day
Old January 2nd, 2012, 08:53 PM
aaronlam's Avatar
aaronlam
aaron lam
My interior lights work perfect than for the front 2 doors... they dim after 10-15 secs. I've seen that "brain." So I assume that wire from the rear trigger ends up there. I'll take a look tomorrow so see if maybe something is loose. Thanks.
97, door, ht, nas, rear door
'97 Nas D90 Sw Le #008/300 Classic Rover For Sale - Vehicles 19 November 28th, 2013 08:53 AM
electrical short '97 NAS D-90 SW blenkush Defender Technical Discussions 1 October 30th, 2011 06:29 PM
WTB Rear Speaker Housing for 97 D-90 SW wadaman Wanted 0 March 5th, 2009 08:44 AM
NAS Rear Tail Gate Stewperformer Wanted 9 March 23rd, 2006 08:35 PM
97 NAS 90 Owner's Manual dnewman9 Wanted 3 January 20th, 2004 12:50 AM
