97 NAS 90 "Brake " warning light. - Defender Source
Old May 4th, 2010, 01:07 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Has me a little stumped: Turn the ignition on or start the car, after about 8 seconds, the red Brake warning light illuminates, but not 100% brightness. Apply the driveshaft brake or jump the low fluid float and the light intensity increases to what I'd call normal. Disengage the driveshaft brake or remove the float jumper, and the light extinguishes for about 8 seconds, and will return again at it's diminished intensity.
I suspect the bulb check unit maybe back feeding internally, but I don't know where it is.
Yet.
Help?!
Also, it has an aftermarket alarm with about 42 wires going into the control unit. The current owner doesn't uses the alarm- no remotes- and the doors lock and unlock electrically with the ignition, but when I disconnect all of the harness connectors into the ecu, it does not affect the Brake warning light. (The doors will no longer lock or unlock and the actuators must be very strong as I can't move the lock buttons).
Thoughts?
Trevor
Email is
Same place, new dogs.
Old May 4th, 2010, 03:27 PM
fenwaystan's Avatar
fenwaystan
Christopher Giles
1997 D-90
Okay, I am going to mess up the terms, but here goes. I had the exact same problem and the "screen" type contraption in the break fluid reservoir simply needed to be cleaned (sprayed out with WD-40) and put back in. It solved the problem in minutes. Make sense?
Old May 5th, 2010, 06:50 AM
Roverlab
Trevor Griffiths
Seems logical, but even if I disconnect the wires to the float and jumper them, eliminating the float from the equation, I still have the same condition.
Email is
90, 97, brake, ht, nas
Safety Devices NAS 90 roof rack rear ladders and parts ECR The Vendors Loft 3 March 1st, 2010 08:29 AM
Weird brake light issue on my 97 Please HELP! Cyborg Defender Technical Discussions 8 July 12th, 2009 01:04 PM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
94 NAS 90 Owner's Manual JRowe Wanted 0 January 20th, 2004 11:03 AM
