My tranny cooler lines wore a hole into the low pressure a/c line and my aluminum welding skills turned a pin hole into a dime size hole. I have temporarily plugged it with epoxy however I need to replace the line sooner or later. Another problem is the nut holding the line to the evaporator inside the truck is on TIGHT and I can't get it off either. I think i will dremel cut the nut when I replace it but before I start that I need a new hose.
Does anyone know of a source other than factory OEM or RDS that I can get a hose? I am not sure if Disco's use the same side or not? Again its the low pressure side I need.
Any thoughts?
Dennis
Any thoughts?
Dennis
