97 locked in park - Defender Source
Old October 29th, 2006, 12:26 PM
mountaintek's Avatar
mountaintek
Tom Pritchard
1997 90
97 locked in park
I haven't run truck in about 2 months. It needed a jump, started right up and is now locked in park.
It was running fine when parked andno one has done any work on it in the mean time.
Any suggestions?
Old October 29th, 2006, 12:31 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
We saw this on a friend's truck I think. If you look in the shifter there's a little linkage that gets stuck. IIRC there's a little panel on top of the shifter. Pry that open and jiggle the linkage under there and you should be good.
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old October 29th, 2006, 12:44 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Check your rear brake lights, also check the brake switch.
John C.
Old October 29th, 2006, 04:05 PM
Defender50th's Avatar
Defender50th
James
'94 NAS AA Yellow
As Tony says, pop off the panel on top of the shifter and check in there. There is a little clip in there that holds it together and if that has come off you cant move it, i had it happen.
Best regards
James
Old October 31st, 2006, 02:17 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
Since '97's are automatic transmissions, if the brake light switch is broken, you won't be able to get it out of Park. Same thing if you have a dead battery.
Old November 1st, 2006, 10:05 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
The brake lights are the culprit if they are not lighting up when you step on the brakes. Pop the hood and near the firewall on the drivers side is a wire with a plug that comes from above the steering column. I took a paper clip and bypassed the plug. I pulled it apart and stuck the clip in both ends and the shifter worked. I reconnected it and everything was fine. It happened again a few months later. I cleaned the connection better this time and have been trouble free for some time now.
Old November 1st, 2006, 10:30 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
If you are thinking of my truck, I couldnt remove the key after putting it into Park and shutting it off, which the solution above fixed.
Chris von C
[/size]
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 09:45 AM
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Paragon Park and Rausch Creek - 8/3-6/05 Troys Trips, Trails and Events 1 July 23rd, 2005 10:42 AM
Paragon Adventure Park, Labor Day Weekend 2003 - Pennsylvania USA chrisvonc Trip & Trail Reports 0 June 19th, 2004 01:18 PM
Superlift ORV Park in Hot Springs, Arkansas Nov. 20-23 Joe B Trips, Trails and Events 5 November 12th, 2003 10:07 AM
