97 LE digital odometer issues - Defender Source
Old September 12th, 2014, 12:22 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
So I am doing a rolling resto on a 97 LE, and the odometer is missing a couple lines on some of the numbers and it seems to fade out and in a little. How do I address this? Is it repairable? I know I could order a replacement but from what I understand the needles are different and ultimately would rather retain the original gauge if possible. Thoughts? Resolutions?
Old September 12th, 2014, 12:33 AM
rtgoldenb's Avatar
rtgoldenb
Tyler
1997 D90 NAS
I had a similar issue. Not sure if this helps...
http://www.eastcoastrover.com/speedo.html
Old September 12th, 2014, 12:36 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
You're talking about the digital odometer right? Send it out to North Hollywood speedometer. I've been using them since my big restoration days with Ducati singles.
Old September 12th, 2014, 12:37 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Grassy ass
Old September 12th, 2014, 12:39 AM
rankar's Avatar
rankar
I should've read your thread subject line. For speedo work, I always budgeted $250 with them. Not sure where they would be today but probably not far from that.
Old September 12th, 2014, 07:42 AM
the rover shop
shayne young
Jay at lauderdale speedometer does them for me.. Replaces the display...
Old September 12th, 2014, 07:50 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I recall the guys at Hollywood telling someone that needed a. 97 repair they've given up on LR speedo.
Old September 12th, 2014, 08:46 AM
I can understand if you have the original speedo and want to keep it pure, but you can replace that speeds with a VDO programmable for under $200. I have a 97 digital in mine and I have to use a flashlight to be able to read the numbers for quite some time. piece of crap. waiting til the budget allows me to prioritize that vdo.
Mark Kellgren
KM4BOR
Old September 12th, 2014, 09:00 AM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
NorthHollywood speed-o still does them, i sent 2 to them this week. =)
Old September 12th, 2014, 09:08 AM
Can they set the odometer to a specific mileage? I'd consider fixing mine if I knew the fix was an ECR style permanent fix and i could set the mileage to indicate my actual transplant engine mileage, since it's a transplant from a different vehicle. (I did the mechanical to digital swap on mine).
Mark Kellgren
KM4BOR
Old September 12th, 2014, 09:13 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
We use North Hollywood now.
You'll need to ask them about the mileage set though (never asked).
The FL guys do the job, but they replace the guts so the speedo does a needle sweep when the ignition is turned on (like an aftermarket VDO unit does) (or at least they did the 1 time we tried them out). The factory 1997 speedo never did that, so picky people can pick up on it if you are selling. The N. Hollywood guys use the right parts so that no one can tell you have repaired the speedo.
Email:
Old September 12th, 2014, 09:34 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
can you send me contact info Keith?
Old September 12th, 2014, 11:31 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
http://www.nhspeedometer.com/
Old September 12th, 2014, 12:43 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
talk with kevin there - 818-761-5136
Old September 12th, 2014, 03:28 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
For what it's worth for you 93-95 guys, north Hollywood made me up a couple of upper speedo cables that are NLA.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old December 4th, 2014, 04:56 PM
Grandy
Matthew
'97 NAS D90
For the digital odometer (1997 NAS Defender) are the miles stored in the internal computer or in the odometer itself? or both? I'd like to have my odometer display fixed (rather than a replacement gauge) which will take two weeks. If I continue to drive with the speedo/odo out of the car would there be a discrepancy between the guage and the computer? Thanks, as you can tell I'm not too familiar with defender dash parts!
Old December 4th, 2014, 07:18 PM
It's only stored in the odometer. Nowhere else.
Old December 8th, 2014, 04:48 PM
Nashville's Avatar
Nashville
Victor Hess
1997 Defender 90 NAS
I shipped mine to Hollywood Speedo to replace LCD. My original and accurate mileage was there when I got it back and functioning.
1997 D90 ST NAS #1426
British Racing Green
Wtb: speedometer w/digital odometer Paul K Wanted 5 June 16th, 2014 10:42 PM
help with odometer issues anuctoo Defender Technical Discussions 10 April 17th, 2014 08:00 AM
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
digital odometer reset Overlander Defender Technical Discussions 5 May 15th, 2007 10:03 AM
Odometer -- Digital vs Analog smenzel Defender Technical Discussions 8 August 13th, 2004 11:29 PM
