97 Idle Problem - Defender Source
Old January 8th, 2007, 04:49 PM
gtg067i's Avatar
gtg067i
Christian Shea
1997 Defender 90 Wagon
97 Idle Problem
I did a search and there doesn't seem to be any posts specifically addressing the problem in a 97. After a 225 mile drive home yesterday in driving rain I got in last night and in park and neutral it will idle around 1400 rpm and in drive around 1000-1100. Today I did a quick errand and it did the same for about 3 minutes then settled down but didnt on the way back. It sounds from reading that it could be any number of things. Should I look at the stepper motor first? IF so how much does one cost to replace?
Also the truck has a supercharger, could this be the issue?
I require your largest, cheapest, most alcoholic brewed beverage.
Old January 8th, 2007, 05:02 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I forget the reason why but if I recall correctly they are supposed to do that here and there. I know occasionally I will start mine (95) and it will idle at about 1500- 2000 rpms for about 3 minutes and then settle to idle. Again, I forget the reason why but i'm pretty sure it's normal if it is settling down to a normal idle in a few minutes. My brother has a 94 and his does the same thing. On the flipside, I don't know anything about the oddities of supercharged 90s. I have enough issues naturally aspirated...
Old January 8th, 2007, 09:28 PM
Andrew Vick
Andrew Vick
95 D90
Supercharged throws a wrinkle in it, but I'd start with the basics. Stepper motor: pull it out and clean it. Check for vacuum leaks.
97, idle
97 electrical problem Campbell Defender Technical Discussions 13 January 7th, 2010 04:29 AM
Idle problem - Throttle position sensor? JBfoot Defender Technical Discussions 20 January 7th, 2008 11:45 AM
High idle problem MAF ? TPS? other? MonLand Defender Technical Discussions 30 February 5th, 2007 03:33 PM
Idle problem - need advice fleabus Defender Technical Discussions 24 February 7th, 2006 06:36 PM
Odometer problem 97 jorge Defender Technical Discussions 3 November 19th, 2003 01:13 AM
