97 Fuel Pump Relay Location? - Defender Source
Old April 28th, 2007, 12:27 AM
fleabus's Avatar
fleabus
Dan
None :(
Got in the truck this afternoon to go buy some limes, turns over like a champ, but doesn't start. I also don't hear the familiar fuel pump hum when I turn the key as I normally would.
I started checking the fuses in the center console and all looks normal.
After reading through dozens of threads it sounds like I need to check the fuel pump relay, but I don't know were to look. Some threads mentioned silver boxes, under the seats or in the engine compartment in a white metal box??
Can someone please point me in the right direction? I really need some limes
Cheers!~
-Dan
Old April 28th, 2007, 08:04 AM
they should be in the passenger side seat box at the back, two little silver relays, I am not sure the difference between the 95 and 97 so I am assuming
Old April 30th, 2007, 12:27 PM
GYM's Avatar
GYM
Gary
97 SW
Cheers!~
-Dan
Dan:
Talk about coincidence. I had the exact same problem this weekend with my '97.
Like you, I researched many threads, trying to focus on ones with problem '97's. Two posts "Fuel Pump, Switch, Relay, or Wiring" and "97 NAS Stalls Out and Dies" both from 2005 appeared most applicable to the '97:
...Fuel pump relay is next to engine compartment relay in the engine compartment....
The '97 uses one multifunction fuel pump relay. George @ RDS doesn't carry it. AB has the genuine part in stock. Their item # YWB100820LG.
Garth
Old April 30th, 2007, 06:16 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
I thought the fuel pump fuse was in the engine compartment on the '97's (if I'm remembering correctly)?
The relay in the '97's is in the engine compartment as well, inside a white rectangular box on the passenger side.
97, fuel, relay
Fuel pump relay 95 D90SW alaskajgg Defender Technical Discussions 32 September 18th, 2006 10:26 AM
