'97 fuel pump relay - Defender Source
Old May 23rd, 2008, 06:10 PM
defender1844
Amit Likhyani
'97 fuel pump relay
OK so I took off the white cover and moved the ECU out of the way. I saw 2 harnesses going into a box. Is there anything I can do to diagnose this other than look at power at the fuel pump itself using a test light?
My theory based on the 94 and 95s was that I could swap relays and see if my fuel pump would at least make a noise. That does not appear to be an option in the case of the '97. Can someone confirm?
Best,
Amit
Old May 25th, 2008, 02:45 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
Stupid question - you checked the fuse, right?
Old May 25th, 2008, 11:28 PM
defender1844
Amit Likhyani
yes.
97, fuel, relay
Fuel pump relay 95 D90SW alaskajgg Defender Technical Discussions 32 September 18th, 2006 10:26 AM
