97 door handle retaining screw - Defender Source
Old July 2nd, 2007, 11:29 AM
artm
Arthur Maravelis
97 SW
The front of a door handle has pulled away from its screw. Taking off the door panel, I see that there is a screw (A) threading into a piece (B) with threads on the outside which thread into the plastic handle.
My A is rusted into B so this entire assembly has pulled from the handle.
I'd rather not replace the entire handle. Has anyone reattached this assembly? I suspect that the plastic threads in the handle are worn and may need some teflon tape or such. Or, glue the replacement B "permanently" into the handle?
97, door
97 Gas pedal questions shawnpalmer Defender Technical Discussions 3 May 5th, 2009 05:19 PM
Need fuse box thumb screw evilfij Wanted 1 June 20th, 2005 10:24 AM
97 defender st - headlight retaining screw Rob Defender Technical Discussions 1 April 25th, 2005 06:22 PM
Door hinge screw replacements - guidance paulb Defender Technical Discussions 4 September 22nd, 2004 06:51 AM
