97 Defender 90 Custom Centre Console - Defender Source
Old August 19th, 2016, 11:22 AM
poonstar
Vincent
1997 Defender 90
After finally pulling the trigger and picking up my 90, it was time to add my personal touch along with some audio features because listening to road noise and rocks hit the underside was getting old. My 90 didn't come with a stereo but it had this aftermarket centre dash piece that was hacked into place but since I want to restore to the original dash I needed to look for other ways to install a nice 7" LCD screen, amp, sub and speakers.
So I decided to rip out my centre console and make my own...it is still a work in progress and I came up with this idea at the diner over breakfast on a greasy napkin and put it together that afternoon. Your thoughts are appreciated and any ideas would help!
My centre console will hold the stereo head unit, 5 channel amp and includes a sealed sub enclosure. I have spray sealed the console to protect from moisture and then get upholstered to match the original interior.
Old August 19th, 2016, 01:06 PM
TNRoverGuy's Avatar
TNRoverGuy
Chris H.
'97 NAS D90 ST
Looks like solid work. You mentioned your truck didn't come with a stereo. Do you have a picture of what was in place when you got it?
Old August 19th, 2016, 03:06 PM
poonstar
Vincent
1997 Defender 90
The centre of the dash had an aftermarket Mud UK double din piece that was installed but nothing was installed to the surface besides the rear wider switch. When I took it off, the lower dash was cut apart and the vent openings are behind it with some lose wires.
Old August 19th, 2016, 03:27 PM
doktorno
Chris deZ.
1995 Defender SW
What size subwoofer? Looks like a large air volume.
Old August 19th, 2016, 11:03 PM
poonstar
Vincent
1997 Defender 90
The seal portion of the sub enclosure almost 0.7 cubic ft. I am running a JL 10" TW3 shallow depth dual voice coil sub woofer.
Old August 20th, 2016, 08:49 AM
Probably going to be too much sub unless you really love to pump da bass. I have a 10" shallow depth on my rear tailgate, and it's fine when the top is off in the summer but with the top on in the Winter it's a bit much in the enclosed space. Too late now of course but just my 2 cents.
Old August 20th, 2016, 09:51 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Where are you going to mount the shifter? ...or is this truck a 5-speed?
Rent my
Old August 20th, 2016, 11:09 AM
poonstar
Vincent
1997 Defender 90
The console is between the seats and doesn't interfere with the standard 5 spd shifter position.
------ Follow up post added August 20th, 2016 09:13 AM ------
It's all about dat BASS... Thanks for your feedback!
But in all honestly I was prepared for that and we have templates ready for a 8" shallow mount for that reason. In a super perfect world, how awesome would it be if I could have a quick detach and swap consoles from 8" to 10" back and forth...one can only day dream
Old August 20th, 2016, 11:19 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
I have an 8" focal on my rear door and it's perfect... Quick enough to catch the snares and deep enough for real world base. If you want to shake the car next to you though it won't.
Old August 20th, 2016, 11:59 AM
poonstar
Vincent
1997 Defender 90
Are you guys using a custom rear door card for your 8" sub enclosure? Local stereo shop suggested two 8" subs in a sealed enclosure but space was a concern so I went with a small sealed 10"
Any pics?
Old August 20th, 2016, 12:12 PM
doktorno
Chris deZ.
1995 Defender SW
I have had some experience with the TW3/TW5 drivers, and have found them to be power hungry and requiring a parametric EQ to take out their natural resonance frequency. Installations using the "standard" subwoofer design like the 10W3v3 have had a sound that I found more satisfying. If you have the depth, I might suggest looking into 10W3v3. Your ears may vary.
But damn I like the look of your center console.
Old August 20th, 2016, 12:18 PM
poonstar
Vincent
1997 Defender 90
Thank you for your feedback. The head unit has a built in 13 band EQ and I was thinking about adding a Audison bit one as well but won't know until I plug it all in and wire it up Monday.
Old August 20th, 2016, 01:00 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
10" is just fine, IMHO. but I like the bass. I am running an 8" and it is fine--but there are some super deep basses in some of my music that I could always use just a little bit more... (ie How do you want it/2Pac or Hypnotize/BIG).
Old August 20th, 2016, 01:04 PM
Any pics?
Yes here's a pic of mine. All in with 10" sub, sub box, and rhinolining it's under 25 lbs which was important to me.
Old August 20th, 2016, 01:05 PM
poonstar
Vincent
1997 Defender 90
Perfect! Two of my favourite songs
Where did you mount your all your stereo gear?
------ Follow up post added August 20th, 2016 11:06 AM ------
Looks super clean and tidy. Do you run a soft top all the time? Or do you run a hard top with seats too?
Old August 20th, 2016, 01:18 PM
No top almost always, but yeah otherwise just a soft top which really amplifies the bass. Here are some pics with the seat in place.
ID:	156023   Click image for larger version
Old August 21st, 2016, 03:30 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Here is a pic of mine
Old August 21st, 2016, 11:51 PM
poonstar
Vincent
1997 Defender 90
What type of enclosure is that sub mounted in?
Old August 23rd, 2016, 12:35 AM
poonstar
Vincent
1997 Defender 90
Test fit and pre wire completed after spending a day messing around. Everything works great except I need to find another location for my front channel speakers. Underside of the dash doesn't have enough space even with 1" spacers. So it will be door panels or somewhere else.
Even with just the rears and sub it sounds fantastic. Sub woofer in a sealed enclosure is solid and tight sounding. Really happy with the results, just need to take it apart and have the console wrapped.
90, 97, console, defender, defender 90
Range rover classic centre console.. the rover shop For Sale - Parts 0 January 19th, 2015 12:53 PM
Wanted centre console fuse cover Himalaya Wanted 2 October 21st, 2013 12:25 PM
Td5 Style Centre Console Sale RoversNorth The Vendors Loft 10 December 30th, 2012 03:09 PM
Got the Ashcroft Centre Console installed Reese_D90 Defender Technical Discussions 17 May 12th, 2012 04:17 AM
Looking for 97 NAS90 centre automatic console DEF110 Wanted 2 November 22nd, 2005 02:24 AM
