97 d90 won't start again... - Defender Source
Old June 17th, 2012, 02:14 PM
cafemosaic's Avatar
cafemosaic
steven n
1997 D-90 ST, AA Yellow
i have had this problem a few times now...usually after driving it around town...i runs normally until turned off, then when i go to restart it, it wont turn over...it seems to be trying to start, so not a battery issue, but wont catch...
the last two times, i had it towed to the shop, only to have it restart normally the next day ....
this morning i tried to recrank it and would not start... tank is full.
does anyone have any idea what this mysterious no crank issue is? thanks much
Old June 17th, 2012, 02:46 PM
So it goes click but the starter doesn't spin?
Sounds like you need a new starter motor. They do this when they are hot and old.
I'd probably strip it and clean it ... But then I'm cheap like that!
Old June 17th, 2012, 02:51 PM
cafemosaic's Avatar
cafemosaic
steven n
no it definitely spins...feels like it just wont catch....
just wont turn over...would that hapen sometimes and not othrets?
Old June 17th, 2012, 09:33 PM
Yes. Check ground straps too
Old June 18th, 2012, 11:05 AM
cafemosaic's Avatar
cafemosaic
steven n
its the fuel pump....anyone have one for sale?
Old June 18th, 2012, 11:12 AM
there were 2 for sale about a month ago
Old June 18th, 2012, 12:05 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The thing that is the biggest reason for fuel pump failure is continuously keeping the fuel level low in the tank. The pump relies on being submerged in fuel to keep it cool. Running low on fuel causes the pump not to be kept cool enough and over time it over heats and fails.
I feel your pain.... with the poor fuel economy of the 4.0, and the small fuel tank you'd practically have to visit the gas station daily. Try to keep your tank at a higher level than 3/8's of a tank.
Old June 18th, 2012, 12:59 PM
Captain Spalding's Avatar
Captain Spalding
Captain Spalding
Originally Posted by Dennis View Post
The thing that is the biggest reason for fuel pump failure is continuously keeping the fuel level low in the tank. . . .
That's a nice little tidbit to file away. Thanks!
Old June 18th, 2012, 02:23 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
only problem with that is my trips would truly be measured by fuel stations...just replaced my fuel pump, but I rarely let it go below 1/4 tank most times I fuel up around half...
90, 97, 97 d90, d90, start
97 d90 hummer16 Defender Technical Discussions 4 November 24th, 2005 06:25 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
NRP COMPLETE Exhaust for '97 OBDII D90 dmarchand For Sale - Parts 9 September 30th, 2004 09:07 AM
For Sale: '97 D90 ST-1791 Alpine White jwebster For Sale - Vehicles 0 September 30th, 2003 12:36 AM
